CYC PHOTON
Not sure if it means that they have Photons in stock if they say shipping takes only 15 workdays? So they might have warehouse somewhere closer than Hong Kong then? Hard to understand which dealer is the best to use in Europe or just use the cyc website directly.
Add photon to cart and you will see that not a single unit is available.
Basically those motors only exist on jpg images and not in physical form.
Basically CYC PHANTOM. That's the real name now.
Tried to order another CYC display and it was available. That might be irrelevant though.
CYC peripherals:
Just a quick post about my experience with the peripherals supplied with the Photon, which might help some people on the fence about which options to consider. I'll get around to a separate post about the CYC battery later.
Here's the bike and this also gives you some idea of where I use it - this is not for regular street use or commuting. YMMV.
I ordered the 4-wire harness, with additional brake sensors. I wasn't intending to fit these on my bike, though that harness is necessary if you want to add a 3rd party gearshift sensor, for experienced riders this is not necessary. I chose this for future proofing should I move the system to another bike. In retrospect a 2-wire harness would have been just fine, and replacement harnesses are available and are not expensive anyway. I just heatshrinked over the spare connectors to protect them and tucked them out of the way. There is plenty of length in the harness, in fact I would have preferred a shorter one. YMMV but I doubt the standard harness will be too short for most installations. For installation I used black electrical insulation tape, since it matches the colour of my frame and is practically invisible. It will deteriorate over time but is easy to replace and won't damage the frame or wiring, and is easy and cheap.
I also ordered a throttle. Although I hadn't intended to fit the throttle, (and it may not even be legal where I live) it is really useful if you want to use lower assist levels but retain the ability to add an instant boost for passing or difficult terrain. You can ride through deeper water without getting your feet wet. Or you can stop pedaling if no one is looking :)
The throttle is quite bulky. It looks appalling from the front, the clamp and body are huge, but at least it seems solid. The mounting clamp screw hasn't been recessed at all, this is very agricultural. It fits adjacent to the left handgrip, and I usually operate it by rolling the edge of my thumb into the angle between the blade and the clamp, rather than pressing on the blade directly. This gives more control and is very comfortable, allows you to control very smoothly and consistently. I may remove some of the blade so it gets in the way a bit less; in my installation it has to sit next to the dropper lever and it makes that hard to access. The throttle clamp is so bulky I can't fit it on the right side because it conflicts with the shifter and controls.
This seems to be a WuXing 300 unit, which is available in a couple of different terminations on AliExpress. At 1/3 of the price CYC is charging. It would be really nice if this product was improved and updated, which I'm sure would be possible, the market for these must be huge and I think these have been around for a long time.
The SW102 display is quite good. It appears to be manufactured by Topology and seems to be similar, or the same hardware, as used by Eggrider for Bafang and other motors, and I'd love to see some of the Eggrider functionality built into the software from CYC - datalogging would be really useful. I'm guessing Topology have produced a customised version for CYC, I hope they can continue to improve and eventually offer some alternatives.
The display, menu and controls are logically laid out and easy to operate, though I find when actually riding, there is effectively no tactile feedback from the buttons (especially the + and - assist level control. The + button is very close to the M key and easily mistakenly operated. There is a huge difference between using these controls to go through the settings (which all works perfectly) and actually out riding.
There are 4 assist levels, 0 and 1-3. Unfortunately it is too easy to select 0 without realising it, since the only status display is a small digit in the top right of the display. I quite often find my self repeatedly selecting + or - and then working back from 3 or up from 0 to get the level I want. I would prefer a slight long press to drop from 1 to 0; I've even found when using walk assist, if your finger bounces off the key, 0 is selected.
I also have concerns about the fragility of the display, it projects a long way forward of the bars and well above them, and would easily be caught on vegetation or destroyed in a crash. On my bike, I can easily fit both the throttle and the controls between the brake and the handgrip, especially as I use one-finger braking on this bike (I fitted larger rotors - also, BTW this is the rear brake, which is the non-braindead side for a rear brake) and despite this, the display unit still seems vulnerable. It is interesting there are a few 3D printed protective covers for the Eggrider, so others seem to share my concern.
I would like to see a horizontally oriented unit, with the + and - keys to the left and the display positioned over the brake lever clamp, similar to the DZ41 displays for Bafang systems. DZ41 Display - Google Search
I'd also like to see more configurability of the display. I don't need to see the speed, since I use an Xoss G+ GPS for that, but I would like to see either the assist level in large digits, or the other motor parameters. Currently all of those are really too small to be very useful.
And since I don't think anyone is making one yet, how about a thin minimal display unit that can be stuck onto the top tube behind the headset? That would be a lot more discreet and less vulnerable. I'd be happy if it just had LED displays for assist and battery level or just showed a level gauge for each on an OLED display.
The OLED display however, is fantastic. It is very bright and easily visible in all conditions and when wearing polarised sunglasses. Really happy with that aspect, good job Topology and CYC. Overall, it is pretty good.
The speed sensor is easy to fit and comes with a cable that is slightly long, you'd need to have very long chainstays for it to be too short. I fixed my sensor in place with VB tape and zip ties, it is very secure.
My kit was supplied with no sensor magnet, CYC was extremely responsive and sent a magnet immediately; I was quite impressed, and they are supplying quite good magnets. In the meantime I had temporarily made my own magnet, using a couple of 8x1mm magnets inside a heatshrink cover, and zip tied to a spoke. This works surprisingly well, though it is important that you never slide the magnet away from where the sensor can see it; to do so would remove any speed restrictions and this would be foolhardy and could be dangerous, possibly cause injury or death. So whatever you do kids, don't remove that speed sensor magnet...
I wonder why we even need a speed sensor, since the wiring and installation could be simplified and tidier without it. When a GPS costs <$40NZD with its own case, charging port, controls, firmware, battery and display I would have thought it feasible to build GPS functionality into the control or display for cheaper than all the external hardware associated with the speed sensor.
Sorry if this is a bit long, but it may be of use to some people. I'd be interested what alternative displays are known to be compatible with the Photon system if anyone has experience with any. Same for throttles.
i must say that their approach to battery seems odd and not practical... why not customized hailong type ? with rail ...
Because non-military GPS for average joe is not as reliable as speed sensor. Some time ago I wrote an app for android using GPS and during testing I had noticed a lot of weird readouts especially if you go under the bridge or next to high buildings. Accuracy is never below 3 meters. Often around 10m.
My app in action
Looks like a beautiful place to ride, and thanks for your review/writeup - my reply chops it up, touching on "likewise" or contrasts between my experiences and yours.
CYC peripherals:
... replacement harnesses are available and are not expensive anyway.
Have you seen the CYC version main harness anywhere yet? I've been hoping to find, at least, an extension, but nothing so far.
The throttle is quite bulky [and overpriced]
Agreed, although at least it has a clamshell mount so it can be installed/removed without much fuss - just in case. My guess would be any of the Bafang throttles would work - especially since the Photon can auto-calibrate to the throttle output voltage range. The throttles are reported NOT COMPATIBLE.
Yep - especially what I bolded - the SW102 display is too small to glance read the text size available. And maybe I've got it angled wrong, but mine washes out completely under direct sun.
I'd love to know what CYC defines as compatible when it comes to displays. I have used a horizontal 750C display with my Photon motor without noticeable issues. No, it doesn't currently display some of the data (like the motor temps), but I'd consider that lack of a feature and not a compatibility issue. And, as with the throttle, CYC can stop gouging us on the display pricing. Their display firmware ain't all that, after all.
I'd also like to see CYC update the 500C display, as a SW102 alternative. If CYC could provide a Bluetooth data integration/feed to a mapping GPS like the Garmin Edge Explore 2, it would be, for me, the perfect display.
CYC Battery:
(Sorry, another long post. Hope it helps).
I ordered a CYC battery as part of my Photon kit. This post is to give some details and share my thoughts and experiences; I doubt many are considering this battery and there may be good reasons not to. YMMV.
The battery I got was the B-52 with Samsung 50e cells. Capacity is 520Wh but output is limited to 30A or ~1500W. This is fine for use with the Photon and I prefer the better capacity than the 40t variant. I am fairly space constrained with my frame, and NZ has a real issue with the availability of reputable battery packs. Shipping is very expensive and often not available. This might be related to us being right in the centre of the Pacific Ocean. Which has its advantages, BTW.
I might have been the first to buy a battery for delivery NZ, because although my order was accepted as part of my Photon order, CYC came back to me and wanted $147 more for shipping. I was not at all happy about that, and notice that they've now added NZ as a shipping destination separate from Australia, with the updated and increased shipping costs. Shipping was Fedex ex USA and very fast, not even 2 weeks IIRC.
The battery isn't shown in any detail on the CYC website. IRL it is quite well presented, and comes in a decent looking plastic case. Unfortunately this is rectangular so tends to not fit most triangular bike frames. However (except for one annoying detail) this would make a decent spare back-packable range extender. Weight is 3kg. There is a mounting rail supplied with the battery, quite well made but next to useless, and I'm not showing that here.
Also included are some really nice velcro straps - these are Omni-Tape, the type where the hooks and loops are intermingled and when you see this in use you wonder WTF Velcro have been so slow to adopt this development (I think they bought the company that developed it). When you use these you won't want to go back to the normal 2-part hook and loop system.
The case is a plastic clamshell with a central zipper closing it. When closed the zipper is right under the battery and against the frame. SMH.
There are fittings on both ends to pass fixing straps through, though I can't see how these would ever be useful. There is an LED level indicator on one top corner, which may cause problems for mounting if you want to use straps. You only need to use the indicator to check while charging, but the button stands quite proud so would be pressed by a strap on top of it. The button area should have been recessed (just like the LEDs) to avoid this happening.
Opening the case reveals a battery unit, this is potted and shrink wrapped, and then potted into one half of the clamshell. This is problematic for reasons I'll cover later. The lid of the clamshell is lined with foam. The case itself seems really nice and is well made, with nice detailing. I just don't think this was the best choice for this application.
One end of the case interior is allocated to the connector for the 5-LED charge level indicator and a blade automotive fuse. There is a spare 50A fuse supplied with the battery. On my sample, the fuse holder was poorly fitted and damaged the foam and was rubbing against inside of the case. One wonders what nastiness is lurking under the potted area.
A bit of work has gone into making these cases, they are quite well detailed.
The battery comes supplied with a very nicely fabricated rail system, and fixes to that with 4 lugs like the one above. I've heatshrinked the lugs on mine with a couple of layers because I can't use the rail system, and I don't want the lugs to scratch the frame.
Why not take the lugs off, you ask? They are just screwed on from inside the case. Remember the battery is potted into one half of the case. Yeah...
I could grind everything off, but that seems a little final. I can't use the rail because it adds too much to the height of the battery, and all of my bike frames have wide and flat downtubes that the rail will not fit around anyway. In any case I would be really reluctant to use bottle cage mounts to mount the battery, these are not intended to carry this kind of weight (on one of my bikes, they've never been installed correctly anyway - thanks Giant).
Likewise it makes little sense to just strap the rail and then bolt the battery to that. Better to put straps right around the battery and tie everything down.
Although the execution of the rail system is well done - the quality looks excellent - the design isn't great. I doubt I'm the only user who just can't use this system. The design decisions make a lot more sense when you consider it as an evolution of the X-series battery and mount system; unfortunately I think CYC should have started completely fresh.
And of course, those lugs get in the way if you want to use this battery as a backpackable range extender. Otherwise, with its shape and rounded corners it would be really good for that.
The power cable is disappointing. This is a mesh covered pair of stiff conductors which looks nasty and attracts dirt and water and is difficult to clean. The XT-90 connector is covered with heat shrink tubing and is not moulded on to the cable, so might have structural issues with extended use. I would have thought an XT-90 connector moulded onto a properly sheathed pigtail would have been a reasonable way to manufacture this battery. This aspect looks like any DIY build. Some of the early motors were shown with this mesh covering on the power cable, and CYC have since changed to properly sheathed cable (probably a preassembled pigtail on the XT-90). They need to do this for their batteries, too.
There is no separate charging connector or port, so to charge you have to unplug the motor - every time - and plug the main XT-90 connector into the charger. This suits me, but might not suit others. The battery pack has no power switch, which some might consider a shortcoming. On the other hand that is less cost and less to go wrong. Also less to get in the way of straps :)
The label shows the battery capacity, some instructions and warnings, but NOTHING about the certification of the battery. CYC website claims:
This product complies with UN38.3, IEC62133, RoHS, FCC, & CE standards​
I would guess that these certifications are inherited from the Samsung origin of the cells, and do not apply to the assembled battery pack. However it was shipped by airfreight via Fedex and ex USA with no problems.
I'm sure there are heaps of people here who can contribute about the certification. I would have thought there was a requirement for the battery pack itself to display certification.
Battery sits on my downtube quite tidily. I can also tie it up under the top tube, where it jams quite securely against the downtube and is very secure. The battery would also fit against the seatpost on the top tube, too.
The tabs just happen to be wide enough apart to fit close to each side of the frame, I just taped some padding (some foam feet and plastic milk bottle pieces) under some polythene tape to protect the frame and help the battery sit nicely, and then lash it into place with 50mm Velcro straps at each end. These cover the tabs and tape and hold the battery really securely.
The level indicator is located right where you'd normally use a strap to hold the battery in place. However a 50mm strap allows me place the buckle in exactly the right place to still access the indicator, and at the same time not press the button. Excellent serendipitous result. I don't think this was designed this way.
End result.
I'm actually pretty happy with this. A Shark or Hailong-type battery wouldn't look any better, and I'd have less confidence in how they attach. Some triangle battery bags might look OK, but that's quite a few straps to attach and remove.
I have no intention of charging the battery inside my house, so being able to quickly remove just 2 straps to remove the battery works really well for me. I'd also consider a second battery which could either be used to extend the range of this bike, or to power a second Photon build.
520Wh works for almost all the riding I do, and for the rest, well, I'll just have to pedal more :)
I'd like to see CYC
  1. change the shape to angled ends (even 30 degrees would fit more frames, kind of like the now discontinued X-series batteries)
  2. retain the moulded plastic case but lose the zip (why would you need to open the case in normal use)
  3. make the mounting rail system lugs removable
  4. make some small changes to the LED level gauge so straps don't interfere with the button
  5. upgrade the power cable to something decent
  6. work on offering cheaper but slower shipping options
I think the work CYC did on the Photon was really good, it fits very well and integrates well with my bike. The battery? Not so much.
If there are good alternatives where you live, they may be worth considering. Otherwise, with some compromises and shortcomings, this battery seems OK.
Awesome write up, I love the length and detail you went into! For the throttle if you don't use it that often and don't mind sacrificing some ease of use and I assume precision these throttles have intrigued me, super small and low key. I have no idea what connector cyc uses though so you might need to swap it out THUMB & TRIGGER THROTTLE - electric bike or scooter
There seem to be a similar range from WuXing, but the one you linked to looks nicer.
Are cranks supposed to turn together with the chainring on CYC Photon with throttle enabled? Haven't seen it on TSDZ2 and BBS02. That's what I saw in the videos. This might mean that motor will clash with the leg power or there will be increased drag due to stiffer sprag clutch than normal being used.
Would that matter for this application? I personally doubt it. And GPS could have a LOT of advantages over a speed sensor.
No they don't in practical use. There is a bit of drag in the seals and clutch so as shown in video they will turn, this is normal, and you don't notice it. In fact if you look at some parts of the video, the cranks turn slower than the chainring, so there is some slip even with nothing on the pedals.
I agree, but I have made it work quite well for me. I think I prefer it to the Hailong type casing and rail mount, which might be OK for street riding. I don't do much of that.
Yes, CYC have added a lot of stuff to their shop, including single main harness (for those who won't be using a throttle) and also 2 and 4 wire harnesses.
Yes, part of the bulk stems from the fact it is clamshell and the sensor unit has to fit beside the bars. There is a 130X version that has a concentric sensor that isn't clamshell, but you only fit these once and on my bike I'd only have to remove the handgrip. I might look into one of them, they are cheap on AliExpress.
Even 3 vertical assist bars and 5 vertical battery bars on the SW102 would work for me most the time. Could be accessed by the Mode key. And for some users, more than that would be confusing anyway.
Hey, it is way cheaper than the Eggrider :)
When I looked there seems to be a few displays and other peripherals that use the same connector so are physically compatible, But when you look at the pinouts they are all different, this is madness. And the connectors are hard to DIY to correct or make adapters. And documentation from everybody seems scarce or non existent.
Kind of OT, but there is another "genderless" velcro system that is very strong; I forget what it is called but the "hooks" are all the same (and are also the straps), and look like teensy tiny mushrooms in rows. Oddly, a quick google for "velcro mushroom" actually finds this type easily, apparently called 3M Dual Lock :lol:
I tried some of the 3M version years ago and it's a good thing it was 3M adhesive, because the hooking was so strong I could see the adhesive deforming and it was about to let go when the hooks finally did, pulling with both hands on the controller case I'd used as a test object (to a flat part of square metal tubing) straight off the surface as a test of holding power. The pieces of this velcro I'd gotten had fairly thick backings with recessed screw holes in them so they could be "guaranteed" to be secure even if the adhesive wasn't sufficient by itself.
I never got around to actually using it to secure something to the bike (CrazyBike2) to test ride it around for longterm reliability testing, but I think if it were secured in the center by the screws (with washers to spread load if needed) and more on the edges or a flat strip on each edge to secure them down, you could probably hold entire batteries to the bike with it, not as straps, but as a "place and stick" mount....
If it were sewn or otherwise attached to the securing ends of quality straps or belts, it would probably make an awesomely strong and secure strap system.
what do u mean "street riding" ? no offroad ? most of bikes i put together have these and are used in heavy mtb tsdz2 conversions
Calculated speed tends to fluctuate in some situations a lot. For example in one second you see 15km/h , then 9km/h and in third second 20km/h. With speed sensor measuring rotation speed of your wheel this is not possible. Calculated speed is stable as rock. No weird fluctuations.
FWIW Garmin has GPS's that connect to wireless wheel sensors and use long baseline GNSS to calibrate the wheel sensor so best of everything, very accurate, and can log that along with all the other fun stuff. Mine also has a wireless pedal cadence sensor, temperature sensor and heart rate monitor all of which get logged and readily display in google earth an other mapping applications...
Hi @pxl666, thanks for the picture link - quite a collection of builds there.
I suspect there's an individual level of comfort with anchoring down our varied weight Hailong tray batteries to bottle mounts, especially to say, just two aluminum threaded bosses welded into an aluminum frame. For example, on a smooth road commuter build, I had a 13.5AH battery on a two-boss aluminum frame, on which I also used velcro straps for insurance. With my heavier & larger capacity batteries, mounted on bikes ridden in rougher conditions, I add 1-2 rivnuts and tie the tray down via all four tray holes.
Overkill - maybe.
The CYC battery can be secured to bottle bosses, but it's not readily removable once the battery is screwed onto the mount. An interesting first attempt, but as @hindesite said, CYC (and others), could do better. There's lots of room to improve the externally mounted battery designs, even though the latest Hailong tray design is, IMO, pretty good.
Garmin also interacts with some e-bike motor systems, such as Shimano.
I was gonna add multi-band GNSS, but ya kinda beat me to it, and I dunno how global or country based the newer GNSS (Global Navigation Satellite System) technologies are.
I've tried out my new Garmin Edge under heavily leafed-out tree canopy rides, and it was steady and stable. YMMV. I do remember my older GPS car navigation devices barfing and choking up in urban environments.
I've tried out my new Garmin Ege under heavily leafed-out tree canopy rides, and it was steady and stable.
Newer GNSS, even consumer units, pretty much all utilize Satellite-based augmentation systems (SBAS), e.g. WAAS in north america, that cover most of the land areas in the northern hemisphere... WAAS is specified to bring accuracy to <3m but typically brings a consumer GNSS to <1m
But that's just for a given sample - averaging samples over time can give extremely high accuracy positions, better than 1cm in consumer units and sub-millimeter in the professional market
Phones have lousy GNSS antennas but benefit from having augmentation from the cellular network - still hard to trust them due to the lousy antennas
A decent GNSS will calculate speed based on the difference between two position samples and typically any error between two samples that have the same satellite view will change very little so speed is accurate in those cases - unfortunately if a satellite that's important to the solution gets dropped then the error before and after can change enough to put a burp in the speed calculation... most units will "filter" out the burps though
The wheel sensor/GNSS combo is ideal for speed sensing though - usually the error in a wheel speed sensor is primarily due to the error in wheel circumference however like averaging position over a long time averaging the GNSS distance the wheel turns over a long time will give a very accurate wheel circumference and similarly give very accurate wheel speeds - much better than the resolution of the speed displayed on most GNSS's...
We are in the process of setting up SouthPAN with Australia, because it would be economically stupid to not do something, the benefits are just too great to ignore. Early days though.
But that isn't going to (probably) ever be available in a <USD$30 consumer cycling GPS ex China or Hongkong, and nor is it necessary. However it astonishes me that the GPS I just got has GPS+BEIDOU+GLONASS+GALILEO+QZSS capability. We're a long way from a military GPS being the size of a back pack, with power requirements and training to match.
The requirements to just give a general indication of speed for cycling are pretty low, and many bikes don't even display speed at all.
BTW in NZ almost all the commercially manufactured imported bikes from the major manufacturers are all speed limited at 25 or 32kph and 250W. This is crazy because in NZ the power limit is 300W and we have no speed limit specifically for bikes at all.
You aren't going to vary appreciably from those speeds if the GPS glitches a little, your own mass will smooth your actual speed out even if the GPS didn't do that already. And even a 5% error would be of little consequence - I can't even see a fraction of that when comparing my speed sensor output to what my GPS displays.
On my Giant Trance, these are not welded - they are just rivnuts. And they've both failed when the bike was practically new, from just carrying a bottle.
On my Silverback it is hard to tell if they actually are welded and they seem secure but I figure if I'm using straps and they work well enough, might as well skip any of the rail stuff completely.
The problem with the cage mounts is that once they start failing, they are done - and replacing is either difficult or impossible (depending on access and how flogged out the frame is in the area). And they really weren't designed for large dynamic loads. The tube wall on my Trance is paper thin.
Yeah we setup C-band correction in the very early days (mid-90's) and did our own high precision L-band a bit later... the typical
SBAS system doesn't cost much to setup and operate so it's a bit surprising that OZ/NZ has been dragging it's feet
I agree - for me speed on a display just isn't important at all on a bike, don't pay attention to it. I do like taking my gps logs and displaying them in google earth and when you pull up the "show elevation profile" it shows all sorts of things in the graph including speed, heart rate, temperature, pedal cadence, etc.
I was trying to correlate my heart rate with speed, pedal cadence or whatever and really couldn't find much correlation - after really pouring over the google earth profiles I finally figured out that my highest heart rates were when I was crossing busy streets! LOL... I don't ride on the streets but the multi-use trails out here do cross some busy ones where cars are often going 55mph or more...
