If FF + Hubsinks isn't enough, the next best option is forced ventilation. You don't have to conduct heat if you simply remove it:I'm thinking about cutting out a space in the side cover for a copper heat exchanger (copper conducts heat better than aluminum by 50%). I first need to measure how much space I will have - because the cassette is also mounted on this side. If there is not enough space, perhaps I will add a flat copper plate. or perhaps three flat plates in the shape of a "pizza slice" - only three narrow plates to maintain the stability of the cover. installation, most likely with screws + sealed with silicone resistant to high temperatures. I'm analyzing this idea - unless someone thinks it's an idiotic idea, I'm listening
edit:
or maybe placing there only flat plate of copper will be great. I mean wery thin to get very good heat transfer. on this side most of you have motor windings so place for put there thin copper exchange is good.
Better than a copper plate, it could be to add a membrane that allows air to pass through but does not allow water or dirt to pass through, but I have no idea if they exist.
If you do this, please add a temp sensor on the stator and gather some baseline data. Then it will be a way to see the results. With liquid cooling, while messy, it’s easier, conceptually, to see why it would be very effective at heat transfer. Under load, the stator temp could quickly spike over 100c while the side covers remain barely lukewarm. 50% greater heat transfer sounds impressive until you compare it to how much heat the weakest link, air, can transfer from the stator to the side cover.I'm thinking about cutting out a space in the side cover for a copper heat exchanger (copper conducts heat better than aluminum by 50%). I first need to measure how much space I will have - because the cassette is also mounted on this side. If there is not enough space, perhaps I will add a flat copper plate. or perhaps three flat plates in the shape of a "pizza slice" - only three narrow plates to maintain the stability of the cover. installation, most likely with screws + sealed with silicone resistant to high temperatures. I'm analyzing this idea - unless someone thinks it's an idiotic idea, I'm listening
edit:
Justin's Pic:Yeah, it's gotten quite cumbersome to find the actual test results scattered amongst this thread for comparison purposes, and we could benefit for sure by having an index post at the beginning that has direct links to each of the individual posts with test data. I may try to make that happen, and in the meantime will try to include the previous test data in with the new one.
On that front, lots and lots of new test data with the MXUS motors on the way, this here is what is spinning in the wind tunnel right now.
If the aluminum is painted black and outside in daytime isn’t it going to be absorbing a lot of heat from the sun? I see there’s infared-resistant paints available. I just made a battery in natural amarid color (gold) after the last black -tinted one would get hot being in the sun.Interestingly enough, doing some research, it appears painted aluminium does indeed radiates more heat, and therefore cools off more quickly (like 25%)
But the paint color does not make a big difference. Black paint would only radiate 1% more than white paint.
Does the colour of your radiator affect its heat output? | BestHeating Advice Centre
Coloured radiators are all the rage! But do certain coloured radiators perform better than others? We explore...www.bestheating.com
But matt radiates better than shiny
Learning everyday![]()
Otherwise the battery is in a thin layer of air and I think the foam transfers heat a bit better. Not that there’s anywhere for it to go but at least a bit of a heat sink.Polyurethane foam is an insulator, so I would assume it has a very low conductivity and would not transfer much of anything between the battery and the foam.
If there’s no airflow and the battery is in a very thermally resistant sealed aramid and plastic box I think the polyurethane will absorb more heat than the air. They’re both bad at getting rid of heat. Is there radiant heating when parts are in contact?Air convects; foam cannot. The air layer has to be very very thin before it won't flow around due to temperature gradients.
If the battery is properly sized and designed for the usage, it isn't going to generate significant heat and won't need cooling.I understand that protecting the battery from shock and vibration is a little more important than cooling though probably in most cases.
