I was about to say the same thing in regards to capacitance.dak664 said:The stored energy is 1/2C*V*V, so you'd need 4x the farads at half the voltage. At a "modest" 350 volts they would store only 1% of the energy. I'd wait for the patents on high-voltage DC-DC converters before I'd get excited.
tostino said:I have no idea how they are going to make a converter that will work, and be efficient at that range of voltages! That is way beyond me.dak664 said:The stored energy is 1/2C*V*V, so you'd need 4x the farads at half the voltage. At a "modest" 350 volts they would store only 1% of the energy. I'd wait for the patents on high-voltage DC-DC converters before I'd get excited.
Abstract:
Ultra high power, high voltage, power electronics is on the verge of a new era. Two new power
semiconductor technologies, the high voltage IGBT and the GCT (Gate Commutated Thyristor) are
improving the performance, simplifying the design and increasing the reliability of applications ranging
from 100's of KVA to many MVA. This paper will discuss the characteristics and application
considerations of these revolutionary new technologies.
2. Applications
The following discussion will focus on power semiconductor devices for applications operating at
output power levels in excess of 100kVA. Generally speaking these applications are more specialized
and considerably less common than lower power applications. Some of the most well known applications
include: Propulsion inverters for mass transit and locomotives, high power industrial drives for steel and
paper mills, and utility power conditioning, including static VAR compensation and flexible AC
transmission. In these applications, limited power device capabilities often force the use of circuit
topologies such as cycloconverters and current source inverters that have limited performance. Many of
these applications could benefit in terms of efficiency and control accuracy through the use of a voltage
source topology. In applications operating from AC line voltages of 600VAC and less, IGBTs with
blocking voltage ratings of up to 1400V have provided an efficient low cost means of constructing high
performance voltage source inverters. In higher voltage applications GTOs (Gate Turn-Off thyristors)
have been used but their limited switching frequency of 300Hz or so, offers little advantage when
compared to other circuit topologies. Clearly, a higher performance, high power semiconductor device is
needed. Today, newly commercialized high voltage IGBTs with blocking voltages to 3300V and GCTs
with blocking voltages to 6000V have been developed to address these requirements.
317537 said:You would have to think that with inventions comes new components. New insulators based on this technology...
http://en.wikipedia.org/wiki/PermittivityPermittivity
EEStor reports a large relative permittivity (19818) at an unusually high electric field strength of 350 MV/m; this would allow the EEstor capacitors to operate at high voltages, allowing them to store more energy than other capacitors. In such a strong electric field, the permittivity usually decreases due to a phenomenon called dielectric saturation, or the dielectric may break down, causing a short circuit between the capacitor electrodes. EEStor's US Patent No. 7466536 contains relative permittivity data averaging 19,818 at a field strength of 500 MV/m.[4] The EEStor patents[10] ascribe their combination of permittivity and high breakdown voltage to the sintering process used to combine the PET plastic, Aluminum Oxide and composition-modified Barium Titanate. This high permittivity in a very strong electric field is the basis for EEStor to claim in their patent[10] energy density of 2526 MJ/m3 (52 kWh or 188 MJ, in a package 4541 cubic inches, or 0.0744 m3). Northrop Grumman filed a patent application in 2006 that theorized similar permittivity and energy density are possible with a different Perovskite-type dielectric.[26] BASF filed a patent application in 2003 that theorized energy densities twice as high are possible.US patent 7023687
The EEStor patents[10] cite a 1993 article [27] and a Philips Corporation year 2000 patent[28] as exact descriptions of its "calcined composition-modified barium titanate powder." In the Philips patent, this material is more precisely identified as "doped barium-calcium-zirconium-titanate". The Philips patent reports a permittivity of up to 33,500 at 1.8 MV/m. The Philips patent does not report the permittivity at a high electric field strengths, but it states it has "a low voltage-dependence," - i.e. that dielectric saturation had only a minor effect. Replacing some of the barium with calcium broadens the optimum temperature range, and replacing some of the titanium with zirconium increases the permittivity. The other doping reduces the Curie temperature, Tc, that allows the peak permittivity to be at 85 °C. EEStor uses an aluminum oxide coating on the barium titanate grains that was not used in the capactors the Philips patent describes.
An EEStor patent[10] references a 2001 patent[29] that uses similar coatings on sub-micrometre particles of modified barium titanate. Under one set of conditions, they achieved a permittivity of only 2400 and did not report the permittivity at high voltages. Their breakdown voltage was 4 times less, a little over 100 MV/m.
EEStor says that purified aluminum oxide, in the range that EEStor, Inc. has certified, can have a voltage breakdown of 1,100 MV/m. The target working voltage of EEStor's chemical processes is at 350 MV/m. [30]
In addition, the July 29, 2008 press release[30] states that the plastic matrix allows for better crystal polarization and that this "along with other proprietary processing steps provides the potential of a polarization saturation voltage required by EEStor, Inc." Polarization by a strong electric field is done in the final steps of manufacturing so that the material will form domains that are oriented in the proper direction for the best permittivity and energy storage. The patent[10] states this is done at 180 C with 4000 V.
EEStor's US patent 7033406 mentions aluminum oxide and calcium magnesium aluminosilicate glass as coatings,[3] although their subsequent US patent no. 7466536 mentions only aluminum oxide.[4] Nickel was mentioned in the earlier US patent as the electrode but the later patent suggests that aluminum (1 micrometre thick) would be a better and less expensive alternative. As stated in the patents, both changes were made possible by selecting the PET matrix (or coating) because it is pliable enough to fill voids at only 180 C.
On April 22, 2009, EEStor announced completion of third-party certification of the relative permittivity by Texas Research International's Dr. Edward G. Golla, PhD., Laboratory Director. He certified that the Composition Modified Barium-Titanate Powders have met and/or exceeded a relative permittivity of 22,500[17] over a temperature range of -20 to 65 degrees celsius.[31]
There is some confusion as to whether Dr. Golla actually did the permittivity tests himself and with his own equipment, or merely witnessed the tests done by EEStor personnel with EEstor's testing equipment. Dr. Golla was at EEStor as an independent consultant hired by EEstor and did not represent Texas Research International.
Permittivity is a physical quantity that describes how an electric field affects, and is affected by, a dielectric medium, and is determined by the ability of a material to polarize in response to the field, and thereby reduce the total electric field inside the material. Thus, permittivity relates to a material's ability to transmit (or "permit") an electric field.
It is directly related to electric susceptibility. For example, in a capacitor, an increased permittivity allows the same charge to be stored with a smaller electric field (and thus a smaller voltage), leading to an increased capacitance.
MitchJi said:Hi,
Things will heat up when they produce a working prototype and demonstrate they can affordably mass product them. (They claim the only potential issues are mass production and that they are in the process of building a production line.)EVnewbie said:Since EEStor has applied for a UL listing, once that is granted then things will heat up with the tech.
swbluto said:Having a working prototype would be good enough for me. Having an "affordable mass produced" unit is relative, and I think something like this would be worth many times that of an expensive lithium battery of the same energy content.
I know that once a working prototype is produced, competitors will arise to match the product (eventually) since the competitors will then know it's possible to make, and we can all look forward to at least a minimally guaranteed future.
http://www.greencarcongress.com/2007/01/eestor_announce.htmlEEStor Announces Two Key Production Milestones: Automated Production Line Proven and Third Party Verification of All Key Production Chemicals Completed
CEDAR PARK, TEXAS--(CCNMatthews - Jan. 17, 2007) - The first EEStor, Inc. automated production line has been proven to meet the requirements for precise chemical delivery, purity control, parameter control and stability.
In addition, EEStor, Inc. has completed the initial milestone of certifying purification, concentration, and stability of all of its key production chemicals notably the attainment of 99.9994% purity of its barium nitrate powder.
The independent 3rd party chemical analysis was completed by Southwest Research Institute, Inc. located in San Antonio, Texas under contract with EEStor, Inc.
With these milestones completed, EEStor, Inc. is now in the process of producing on its automated production line, composition-modified barium titanate powders and is moving toward completing its next major milestone of powder certification.
EEStor Announces Two Key Production Milestones; 15 kWh EESU on Track for 2007
17 January 2007
EEStor, the developer of a new high-power-density ceramic ultracapacitor (the Energy Storage Unitâ€â€EESU), has broken a long public silence and announced reaching two key production milestones. First, its automated production line has been proven to meet the requirements for precise chemical delivery, purity control, parameter control and stability.
Second, EEStor has completed the initial milestone of certifying purification, concentration, and stability of all of its key production chemicalsâ€â€notably the attainment of 99.9994% purity of its barium nitrate powder.
With these milestones completed, EEStor is now in the process of producing composition-modified barium titanate powders on its automated production line, and is moving toward completing its next major milestone of powder certification.
EEStor VP Says EESUs to be Delivered by End of 2009
By Lyle Dennis, Editor-in-Chief, June 1st, 2009
The drama that is EEStor continues to unfold. The secretive company is known
to be working on developing a radical new type of battery that offers several
times the energy storage at a fraction of the size and weight of modern day
lithium ion batteries. The material would theoretically have several times the
lifespan as well as it isn't subject to the type of degradation lithium-ion is.
The small Canadian firm Zenn Motor Cars is a a partial owner of EEStor and has
an agreement to use the new batteries in its Zenn City electric car as well as to
develop the ZENNergy drive powertrain that can be retrofitted into other vehicles.
Zenn has been waiting for working prototypes since at least 2007, but thus far
none has been delivered. Recently, EEStor was able to prove that its material
had the permittivity required to allow its fantastic properties and did so over a
wide temperature range. Its voltage range and leakage current is not yet known
publicly. Nonetheless, based on this data, Zenn chose the option of increasing
its investment and stake in the company.
In a brand new interview with Tom Weir, who is VP of EEStor, the next steps for
EEStor are laid out.
"Our objective is to complete component testing by September 2009, " says
Weir. "In parallel, we will be finalizing our second objective which consists of the
assembly processes necessary to deliver production quality components and/or
EESU's by the end of 2009."
So there you have it, EEStor has promised to delivered production quality
materials within six months.
The world is waiting.
Source (Bariumtitanate.blogspot.com)
and deliver the first working units to Zenn in the 4th quarter of this year.
liveforphysics said:I wonder if there is a direct trend in battery company stock prices dropping every time EEStor makes a new press release.
I will be over joyed the moment a single EEStor prototype is verified to perform as claimed. We worked the numbers on it here, and it's definitely possible to accomplish what they claim. It will be great to see all battery technology made obsolete over night, along with the mouths of all the doubters being silenced finally.![]()
It would also be great (still not totally convinced) to see my Zenn stock drastically increase in value.Luke said:It will be great to see all battery technology made obsolete over night, along with the mouths of all the doubters being silenced finally.![]()
SpeedEBikes said:They operate at something like 3500 volts. They are currently focused on building 52kwh modules for cars.
Light Electric Vehicles Company (LightEVsâ„¢) intends to provide electric two and three wheel vehicles, as well as electric propulsion system products, all using advanced power packs from EEStor, Inc. under our exclusive worldwide technology agreement with them. Our objective is to make better quality light electric vehicles available to the world market at more affordable prices. We expect these vehicles to compete directly with petroleum powered two and three wheel vehicles, and to also eventually replace similar electrically powered products which currently use electrochemical batteries. More information will be posted to this web site as progress is made toward introduction of the EEStorâ„¢ technology.
Vehicle manufacturers of two and three wheel vehicles, interested in using this technology, should contact us via the addresses and/or phone number indicated above.
2009 Awarded contract from EESTOR to integrate Polarity’s high power HV to LV converter into EESTOR's EESU that will be used in Zenn Motor Company’s small to medium size electric car.
