I have been meaning to post my Temp mods which Elinix has posted above.
I had some Permatex steel weld putty lying around so i decided to see how it went at transferring heat. Using a gas torch lighter i placed it near the set piece of putty for a second and then felt it and it was very hot. Not the most scientific but it proved it was good enough for the project.
![motor_end_parts.JPG motor_end_parts.JPG](https://endless-sphere.com/sphere/data/attachments/191/191488-a6b8f304a377d78535c0c62c48d5348e.jpg)
I used some Tesa tape 51036 to prevent the steel putty from sticking to the end of the motor.
The Tesa Harness Tape was also something i had lying around and they say its ok for up to 150 deg. Celcius... so thought that would suit fine. Its probable that other tapes could work.
I kneaded and then rolled the putty into a long cylinder of about 6mm(?) cant remember exactly. I taped over the end of the motor as pictured, then placed the roll in the centre of the outer section. I put the motor back together, pushing tightly to squeeze the putty, then screwed housing back on.
I had it like this for about a month, not knowing whether the putty would stick to the aluminium case, which it didnt.... I installed a temp sensor at this stage (TMP35GT9Z w/ 1uf poly Cap across its + & - ) which works great, thanks to the forum member who posted this! At this stage i also applied a very small amount of thermal compound (Chipquik TC3 - not the best best but not the worst either) to the set putty.
The heatsinks on the main motor housing are for Raspberry pi's, which I bent to suit the motor shape. I also have the Silent Ordanance motor/ housing aluminium gap filler plate.
I am running 48v 15a w/ latest embrusa OSF. I haven't ridden up any huge hills but I rode the other day in Power mode @450% assist, turbo mode, ~31 degrees Celcius. After about 20mins riding back from the beach in top gear and trying to let the motor do all the work the reading was 71 degrees. I only weigh 60kg so that prob helps too. I am pretty happy with the power and thermal mods. Next heat mod will hopefully be one of those wrap around motor covers (stator to cover) from the Polish site
Thermal conductive insert for TSDZ2
To be honest though I hardly ever ride like this and don't use turbo mode much (and usually always in torque sensing mode) There arn't many big hills near me which i think would def. change my mind on cooling mods needed. It certainly is fun though when cranked up!
