athletic91
LATEST SPEC
Build in progress.
Goals of project
1. Total bike weight to be less than 20kg
2. Speed of at least 25km/h
3. Range of at least 30km.
What inspired me to start this project is the availability of cheap CST motors offered by Cute. I currently have a 9 speed shimano system and wish to keep it. The 9 speed cassette should fit the rear hub motor. The motor kit ordered is a Cute 100 CST 36v 218 rpm
I bought the battery locally as i wanted to to make sure it had proper voltage. The sticker says 36v12ah but i believe its more like 8-9ah given its size. Fresh off the charger measured 43v.
Potential challenges faced.
- Motor kit from greenbikekit will arrive before 31 dec? ordered on 20/12/2013- Arrived on the 31/12/13
- Whether it will fit nicely in the rear dropouts without filing- Required some filing, wheel not centred
- Whether I would able to successfully mount the PAS to the shimano hollow tech 2 crank. thinking of mounting the magnet disc and sensor reversed on the left side of the BB- Success
Challenges on arrival.
-Wheel not built centred.
-160mm rotor is pushed too out till it rubs the frame.
Build in progress.
Goals of project
