Hi everyone, I'm in the middle of setting up the Electrify Bike Kit with prewired connectors, and while I had no problems installing the firmware, I'm having some issues with the temperature sensor installation.
I believe this is the 8 wire version, since it came with a throttle and I counted 8 wires coming from the "controls" cable.
After cutting the orange wire, the motor would no longer boot properly, and the display would show the "88888" screen (all pixels activated). Reconnecting the wire resolved the issue. So I soldered a plug in parallel to what I understand are the throttle wires like the wiki says. GND to the black wire, 5v to the white wire, and signal to the orange wire. No issues until I plug in the temperature sensor, which gives me the "88888" screen once again.
After a few times fiddling with it, a new issue arose. Now the motor boots as soon as I plug in the battery, functions normally, but when I try to turn it off the pixels disappear and the backlight stays on. At that point it's frozen and I have to unplug the battery to get anything to happen.
Thanks in advance for any help or advice you can provide.
Update:
I've reflashed the firmware, and the same problems persist.
