kamsai said:
1) The Kona Sutra .... the overall weight is quite heavy then, so is the 250W motor enough for such a load or should I just get the 500W version? For the 500W version I'd need some extra licence (~60€ / year), but otherwise it's ok.
You realize that with 500W continu power the bike is not legal for the EU law, imho an extra license isn't enough to ride it legal. In that case your bike needs a typeapproval and registration for speedpedelec (45km/h) too.
I don't know how strict the rules are maintained if you keep the speed at 25km/h with 500W. There is no size difference or other outer signs, compared with 250W tsdz2.
kamsai said:
2) There are 36v and 48v versions. I've read some posts that say how 48v version is overall better since it doesn't heat as much as the 36v version. Is there anything else good to know, or is the 48v verson just better "out of the box" ? (NOTE: It seems these versions have advantages/disadvantages when using custom firmwares ..
imho there is no disadvantage or difference flashing OSF on 36V or 48V tsdz2. Both are good, but indeed the 48V could have more power and could behave better in your case.
Heating could be a problem with all tsdz2 versions, because the heatmanagement is not that good. You can improve this with filling the airgaps between bare motor and housing. (
wiki and
topic).
Also a adding a
temperature sensor keeps the heat in proportions by lowering the power if needed.
(in that case ordering the 8pin throttleversion made this easier to add)
Also overvoltaging
(48V for 36V tsdz2 or 54V for 48V tsdz2) could help to keep the same max. power with lower current through the coils, which is possible with OSF by setting a power and current limit.
Other disadvantage with Tsdz2 is mechanical and play, wich you can improve a bit beforehand with
2 extra bearings on the spindle.
kamsai said:
3) ... open source firmware .... is there strong recommendations to install some new firmware even for the new setup? If so, any guides for those?)
imho you can flash OSF, it behaves a lot better than stock, but I can imagine that you first want stock FW for a while, so you can compare stock FW vs OSF. Before OSF make a backup of your stock fw, so you are safe if not satisfied.
kamsai said:
.... want to deep dive into this modding more. So what do I need for that? Do I need to buy anything extra cables etc to get custom firmwares installed? I could order those same time I order the motor and the battery.
If you keep your original display, you only need a
STlinkv2 clone
(and maybe some small shrinktube for covering the sockets). Read the
OSF wiki and see
this topic.
kamsai said:
4) .... battery size? ....
Wh is size, weight, distance and charging time, so you need a compromise for your personal use.
