7lucky7 said:Hi all. Happy tsdz2 user for 2 years with about 2k miles on the bike using the osf with great results.
I washed my bike down at the weekend and since have been getting all sorts of issues
My speed sensor is very intermittent. I had a second one and so changed it but with the same result despite no change in position of magnet or sensor.
Even when the speed sensor is working now the motor doesn't kick in at all.
I really don't know what's going on with it and wondered if the controller had got ruined but things like he lights and other functions still work. Any ideas why the motor wouldn't start at all??
Jim
7lucky7 said:So I think it must be the motor (though I can't see anything wrong with it when I opened the housing) because it won't even start up in walk mode. Having intermittent issues still with my speed sensor. Not sure what else to do really except order a replacement motor.
Jim
Chri_Tof said:7lucky7 said:So I think it must be the motor (though I can't see anything wrong with it when I opened the housing) because it won't even start up in walk mode. Having intermittent issues still with my speed sensor. Not sure what else to do really except order a replacement motor.
Jim
Have you checked all cable connections? Maybe water got in somewhere and there is a contact problem.
7lucky7 said:Hi thanks for your reply. This was my first thought, but I've opened the casing, no sign of water, looked at all wiring connections, plus other functions work like the lights and startup doesn't show any problem.
I tried turning the walk assist mode on and that won't work either.
I'm waiting for some circlip pliers so I can inspect the torque sensor but my understanding is even this shouldn't affect the walk assist mode.
If the torque sensor looks fine I think I'll be forced to order a new motor though I don't know what else I could do. If the torque sensor is knackered I can obviously replace it. I don't know how I would test the controller, the vlcd5 turns on and I can go through all functions including lights etc so that to me suggests is ok.
I read one post of something similar where somebody said water ingress into a frayed wire had caused it to break down and corrode but I can't see any evidence of this anywhere inside.
7lucky7 said:FIXED
so I've had everything apart today to try and dry it which didn't seem to fix the problem.
I also posted on the pedelec forum. ( https://www.pedelecs.co.uk/forum/threads/tsdz2-motor-failure-after-washing.43740/ )
Where someone kindly suggested that they had a similar problem and thought it was a controller fault maybe caused by water ingress. They swapped it out for a new one.
I reflashed the software (slight upgrade actually but same settings) onto the old one after a few attempts and it seems to be back up and working fine.
Perhaps some water ingress corrupted the osf hence giving faults with the speed sensor and the motor. But it's fixed for now.
I'll repost if this re-occurs. Feel free to message me/reply if you have similar problems.
beemac said:7lucky7 said:FIXED
Glad you got it fixed, was going to suggest a reflash. I've had similar issues in the past oddly also when I washed my bike. Are you running casainho's osf, if so out of interest what version of the motor firmware are you using? There are some fixes in the version past 1.00 that prevent memory corruption under certain circumstances that I think caused my issues.
V1.1.1 binary of the motor fw is on this page:
https://github.com/OpenSourceEBike/Color_LCD/releases
Oh but I have just noticed that someone posted a bugfix to my changes that I haven't looked at, and that last change isn't included in the 1.1.1 binary. I really need to dig out my dev environment from storage and get coding again...
scrolltonowhere said:I have a question about torque sensing and shifting. Most of the time my bike works really well. I'm still trying to figure out the optimal way to use the Tongsheng assist. Sometimes, I just want to go someplace as fast as possible and am using the whole traffic lane so I'll accelerate fairly quickly. I start on gear 3 or 4 and work my way up to gear 6. If I do this on full assist I can get there pretty quickly. I've found if I use gear 7 which is my highest gear (smallest cog), I'm not sure what it's doing but it feels like it may be slipping with pedal assist on. There's just a kind of an awful tearing sound. I have the intuition that gear 7 should only be used either going downhill with no assist. Would you say this is accurate? Also, would starting on gear 3-4 with full assist be ok for the motor or can I start on a higher gear if I want to accelerate quickly from a stop light? I'm not using the e-brakes so was also curious if I have my weight on the pedals when I'm stopped while clinching my brake levers. It seems to take a little pressure for a few seconds for the assist to kick in so I'm assuming I'm not ruining my motor by not using the lever brakes.
Also, I'm not sure about the optimal power setting I should be used on the controller.
7lucky7 said:Essentially this max torque takeoff in your highest gear is a bad idea. If you start in your highest gear you are putting maximum torque through the motor to get going. And the resistance to turning is high. You'll basically shred your blue gear if that isn't the noise you're already hearing. You don't say what wattage/voltage motor you are using so difficult to help with settings for your controller.
The blue gear is an intentional weak point that sacrifices itself rather than burn out the motor. If you start to get any slippage then I would inspect it.
Wapous said:After about 10k kilometers the teflon tape that protects the ferrite of the torque sensor coil has worn out.
Chalo said:Wapous said:After about 10k kilometers the teflon tape that protects the ferrite of the torque sensor coil has worn out.
Awesome non-engineering! Why bother designing something right, when people will buy it anyway and fix the problems themselves?
endlessolli said:Chalo said:Wapous said:After about 10k kilometers the teflon tape that protects the ferrite of the torque sensor coil has worn out.
Always entertaining - your bickering about the TSDZ2 :lol:
Its not perfect - but I love mine. And such a great community here that helps to make it a pathetically unreliable cheap torque driven midmotor![]()
scrolltonowhere said:7lucky7 said:Essentially this max torque takeoff in your highest gear is a bad idea. If you start in your highest gear you are putting maximum torque through the motor to get going. And the resistance to turning is high. You'll basically shred your blue gear if that isn't the noise you're already hearing. You don't say what wattage/voltage motor you are using so difficult to help with settings for your controller.
Thank you for that. I have a 250/350W 36v motor I actually rarely use the high gear now after I heard that slipping sort of grinding sound. It seems to only occur when I'm going pretty fast in a higher ger (6 or 7) with higher torque especially while going up a hill. Would you recommend I check the blue gear even if this is basically brand new? I heard it the sound and the slippage I described the first time I took it out for a ride and I was trying to cruise along in 7th gear to see how fast it went.
I'll start on a lower torque while taking off from the stoplights as you mentioned.
jeff.page.rides said:scrolltonowhere said:Thank you for that. I have a 250/350W 36v motor I actually rarely use the high gear now after I heard that slipping sort of grinding sound. It seems to only occur when I'm going pretty fast in a higher ger (6 or 7) with higher torque especially while going up a hill. Would you recommend I check the blue gear even if this is basically brand new? I heard it the sound and the slippage I described the first time I took it out for a ride and I was trying to cruise along in 7th gear to see how fast it went.
The sound you hear is most likely the one-way bearing in the blue gear. Just like all the parts, the quality is not consistent. It can be larger than should be bearing, and or the motor shaft could be smaller. It turns up most of the time when there is too much torque, like riding or trying to take off in too high of a gear. I watch Candance and stay above 60 on a light load and 80 on a heavy load.
Elinx said:The tsdz2 default cranks are bowed and has a relative wide Q factor.skestans said:..
What was the solution? I think I remember they could be swapped with another set of cranks that were symmetrical.
Mostly the advice is to replace only the right (drive side) crank for a more straight Bafang type for symmetrical Q factor.
See here too
endlessolli said:.....
3) Why does the µcontroller still work, but refuses to communicate via SWM pin for programming?
-> Measured SWIM Pin and it is shorted to GND (internally in the µcontroller); maybe some ESD accident / error in wiring in the past?
(That could also explain the blown cap, if the same happened on that wire...)
4) Any trouble-shooting ideas?
-> I ordered a new µcontroller (STM8S105S4T6C) and will try to replace the old w/ the new one...
:thumb: Good to hearendlessolli said:.....
Just a feedback to the community: I replaced the µcontroller (STM8S105S4T6C......
:thumb:Wapous said:.....
There is more info about compatibility between TDSDZ2 and TSDZ2B on this Aliexpress dealer's page.....
We only can know this if someone give feedback of this Tsdz2B.endlessolli said:.....
- What are the benefits of TSDZ2B? When this new spragclutch brakes - then what? It is not a generic part like the CK30P. Also - in which flavors does this B Version come? IFX µcontroller? ST one? Random?
