RicMcK said:sysrq said:Not in Europe then.RicMcK said:sysrq said:What about the price of the Loctite 660 and being able to remove the parts again. Seems like the price doesn't outweight the benefit in this case. Not sure about angular and radial misalignment.
The loctite 660 is cheep (very small tube, $8USD -Amazon). I figure I will rig up a puller (with an extra spider) to remove the sparg clutch, if and when I need to. I would rather have it tight and not wear the shaft.
https://www.amazon.co.uk/Loctite-Henkel-Quickmetal-Large-Retainer/dp/B002UNNTZ8
OUCH There are other options that you can probably find locally at a better price.
There is no way to tell by hand since thermal conductivity of air is 0.022 W/mk. Probably the best option is to wait while theyCatfishMan said:So I just went for a relatively short 8 or so mile ride, mostly flat, but there is a pretty long hill coming back. I have the custom firmware and keep my power max at 450. Going up the hill, I did have the PAS on the highest setting. I noticed when I got back the motor was warm/borderline hot to the touch. Is that normal or did I push it too far? Are there "best practices" to keep the motor from overheating? Is even 450w not safe enough?
Gas engines need a flywheel to carry through between the power stroke, and the intake exhaust and compression strokes. the fewer cylinders the more flywheel needed. Electric motors have a more continuos torque out put and even produce torque at 0 rpm. Also the rotating parts of an electric motor are already heavy, and being circular in profile tend to be evenly balanced. One example of the gas engines without a flywheel were the very early 2 stroke radial aircraft engines. The crankshaft was bolted to the airframe, and the whole engine block spun with the propeller attached to it, saving the weight of a separate flywheel.Waynemarlow said:I know gas motors like a bit of flywheel effect to smooth things out, but do electric engines need flywheel effect ?
I wonder if there was any feedback from the guy who machined the pictured gear ?
Always good reasons to operate BLDC motors at lower temperatures. As the temperature increases so does the winding resistance. A 50C temperature increases the winding resistance by 20%. At too high a temperature the rotor magnets can be demagnetised (this has been experienced and documented on this forum for the TSDZ2). Also motors have been burned (potentially the winding insulation breaking down) at high temperatures.sysrq said:There is no way to tell by hand since thermal conductivity of air is 0.022 W/mk. Probably the best option is to wait while theyCatfishMan said:So I just went for a relatively short 8 or so mile ride, mostly flat, but there is a pretty long hill coming back. I have the custom firmware and keep my power max at 450. Going up the hill, I did have the PAS on the highest setting. I noticed when I got back the motor was warm/borderline hot to the touch. Is that normal or did I push it too far? Are there "best practices" to keep the motor from overheating? Is even 450w not safe enough?
http://www.tsbicycle.net/index.php/about/63
improve the thermal management. If they use magnets with higher Curie temperature then there is less reason for thermal management.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=102046&p=1497028#p1497028
mctubster said:Always good reasons to operate BLDC motors at lower temperatures. As the temperature increases so does the winding resistance. A 50C temperature increases the winding resistance by 20%. At too high a temperature the rotor magnets can be demagnetised (this has been experienced and documented on this forum for the TSDZ2). Also motors have been burned (potentially the winding insulation breaking down) at high temperatures.sysrq said:There is no way to tell by hand since thermal conductivity of air is 0.022 W/mk. Probably the best option is to wait while theyCatfishMan said:So I just went for a relatively short 8 or so mile ride, mostly flat, but there is a pretty long hill coming back. I have the custom firmware and keep my power max at 450. Going up the hill, I did have the PAS on the highest setting. I noticed when I got back the motor was warm/borderline hot to the touch. Is that normal or did I push it too far? Are there "best practices" to keep the motor from overheating? Is even 450w not safe enough?
Also better to operate at lower RPMS, which decreases the loses in the core (hysteresis and eddy current losses), and less so windage and friction losses. Core losses are significant.
Is there any literature on the rated torque of the motor(s) in the TSDZ2?
Please read this page and consider if you are upto doing this?ImpulsePurchase said:Sorry if this has already been put to bed (but with 235 pages its a little difficult to find now) - but does the open firmware fix high default torque sensor settings?
I have a brand new TSDZ2 and the unloaded setting (menu under TE) is about 117 (a web search has suggested 75 seems a more normal default). Consequently I don't seem to be able to keep the motor engaged and its useless as a motor (can't notice the difference between off and turbo mode). I was intending on loading the open source firmware anyway as soon as the cables arrive, but not sure if this is permanently borked and I need to suck up the cost of international returns or if I can work around it?
mctubster said:Please read this page and consider if you are upto doing this?ImpulsePurchase said:Sorry if this has already been put to bed (but with 235 pages its a little difficult to find now) - but does the open firmware fix high default torque sensor settings?
https://github.com/OpenSource-EBike-firmware/TSDZ2_wiki/wiki/How-to-calibrate-the-torque-sensor
Is the speed registering correctly? Try riding even without assistance to check. The gap between the magnet and sensor needs to larger than you would expect. Say 5mm or 1/5 inch.ImpulsePurchase said:Magic fairies seem to have gone in overnight to get something working (I enabled the walk mode and lifted the wheel to test and then it started to work afterwards). The stock firmware is showing a lower reading for TE/rE (107) now so not sure whats changed there. Still not consistently working (second trip I had to stop twice to power off and restart (same process of aligning pedals to horizontal and not touching them each time) to get the motor to engage) so something isn't quite right but once its working it seems to stay working.
If I can get it consistently starting I'll probably leave adjusting the torque sensor until I do a service at some point.
mctubster said:Is the speed registering correctly? Try riding even without assistance to check. The gap between the magnet and sensor needs to larger than you would expect. Say 5mm or 1/5 inch.ImpulsePurchase said:Magic fairies seem to have gone in overnight to get something working (I enabled the walk mode and lifted the wheel to test and then it started to work afterwards). The stock firmware is showing a lower reading for TE/rE (107) now so not sure whats changed there. Still not consistently working (second trip I had to stop twice to power off and restart (same process of aligning pedals to horizontal and not touching them each time) to get the motor to engage) so something isn't quite right but once its working it seems to stay working.
Try removing the crank arms and install them 90° further.ImpulsePurchase said:Okay. I think I have figured out why I only sometimes get power. It seems that if I power on at different crank alignments I get different base torque sensor readings and as I rotate the cranks then the base level changes. In my earlier testing my max rE1 I could get by standing on the pedals was about 130 so if my base level was 120 and half way round I'm getting a -10 reading then I can't push hard enough to engage the motor.
I did a video here (sorry its vertical) showing the rE1 settings at different crank settings without any load applied.
[youtube]V3ogs4TPS8Q[/youtube]
This could be something in the way I have installed it? Maybe something not quite square but I can't think what. Any ideas?
cream said:@ImpulsePurchase
Maybe the stationary coil is not positioned/aligned correctly in regards with rotary coil, over the whole crank rotation. Maybe one of the 3 light springs is out of place or the stationary coil is bent. I have a slight variation of ADC torque reading of about 1-2 units over one complete crank revolution, I guess it's normal.
In my riding environment where 30+ mph is required some times, peak power at 3000 RPM looks interesting.najbyk said:I do not know if someone already wrote about the influence of driving style on the efficiency of energy consumption, but I think it is quite interesting. We do not know the characteristics of the TSDZ2 motor. I reviewed several characteristics charts of BLDC motors. All of them have the highest efficiency close to maximum speed. The lower the motor rpm, the lower the efficiency, and hence the more heat. Look at an example chart:
This motor has the 75% efficiency close to maximum rpm. But in half of the nominal rpm (where it obtains the highest power), its efficiency is below 50%. So more than half the power is wasted in the form of heat. It's a lot. Just imagine that half the energy from your battery is lost. This problem is particularly evident in hub motors, which often run at low speeds. They get hot fast.
We can not improve the efficiency of the TSDZ2 motor. Fortunately, the mid drives have the advantage that you can shift into a lower gear and thus increase the cadence and motor rpm. Then the energy is used more efficiently, less heat is generated, and the bike's range is much greater. All in all if your motor temperature is getting high, or you want to save energy, riding with a high cadence should help.
