Keithchris said:
So it seems the battery voltage is creating the problem - I have measured the fully charged battery at 54v - I have the same battery from another bike ( same build ) measured at 47v - using the battery with lower voltage both bikes function OK - with the higher voltage battery one bike ( the original problem bike ) will not ‘start’ the other bike kind of hesitated but eventually did ‘start’ exchanging the batteries a few times bike to bike the problem could be switched on and off.
Is there any recommended action I can take now - apart from managing the charging level of the battery ?
The firmware level shown on the display is 4.1 .
Thank you
No problems. You can either:
A) Change over to the Open Source Code firmware for the motor (If you want to keep your standard display, I prefer the qmarco version of the code fork)
B) Change over to the higher voltage standard firmware (found at https://www.eco-ebike.com/blogs/eco-cycles-instructionals/tsdz2-motor-firmware-programming under the "STOCK FIRMWARE ARCHIVE" at the bottom of the page)
C) Change over to the Open Source Code firmware and update your display to match.
D) Return the motor that has the wrong firmware
I think that covers the options?
