Rix
100 TW
Merlin said:sometimes germany isnt too bad ;P
http://www.shinkoreifen.de/motorrad/reifen/enduro.html
Not bad at all.
Honda CR85 forks are probably your best bet, even lighter are any fork that was designed for Trials Bikes. Most Trials MC forks have between 6 and 7 inches of travel. CR85 has 10.Longshot said:Im thinking about modding some motocross forks to fit the bike. Has anyone considered this? What are the best/lightest forks I should try?
upek said:@Offroader
How much power (volts, amps, phase amps) you can pump into cromotor doing harder offroad without immediate overheating?
Thanks!
Mammalian04 said:At first I thought you were referring to the regular dropout vs. wider Cromotor dropout (165mm) but the numbers don't match yours. You must be measuring the front to back length of the swingarm opening.
Offroader said:upek: I actually maxed out my phase amps on my Max-E, or set it to as high as it would go. My display broke and I can't read anything now but I have it set to something around 360 I believe. It still doesn't have the low end power of my 18fet Lyen.
Maybe I'll unlock it in a year after the warranty is up and increase the power. The Max-E seems to be easily broke and too many people are having problems.
The display especially seems to be cheaply built and that is why my screen is broke and I have to eventually send it back for warranty.
