Sette Relic Downhill Bike Daily Rider- urban commuter
leangains
USA
Here she is. Going to disassemble, sand, fill, and repaint the bike. Will regrease everything, and make sure its good to good. I will be using this bike religiously to commute 20 miles everyday, and 30 on the weekends to do errands. I am attempting to build a fun, reliable form of transport.
This is my first build, and I hope to do this with as little $$ as possible to keep it fun ( very cheap, lol). I am not looking to pedal much, as I have slight tear in knee currently.
Any insight, or free parts are welcome. I will need a BARE minimum of 52v 15ah for my range requirements.
What color should I paint the bike? Here is an orange version:
Here is my Elevation map , this should be enough for your guys to see what I need.
531 ft · 492 ft
Advice...just that at least in places I've commuted, a crappy-looking bike is a lot less likely to vanish than a pretty one. ;)
Until I figured that out, I used to try to make all my bikes look really nice. (these days they're harder to just walk away with, given theirr size and weight, but even so I keep them wiht me or keep an eye on them, or let my St Bernards deter potential miscreants).
debating still on a bbs02/ or hub. Might go lipo again just to get the cost below $200 for a reliable battery estup vs pitching out $600 for an 18650 pack. Ive handled lipos before no problem. Just balanced charged every time, watched for puffing ect.
I hate dealing with torque arm setups. Its easy on disc brake side, but on gear side its always confusing to me.
I notice alot of hub builds use singlespeed gearing, and some run no rear disc just regen. Any information on a simple setup like this?
is regen strong enough to not run a rear disc? With 1500w of power I doubt pedaling would do much input, hence the ss gearing?
Depends on the regen setting and/or capability of the controller.
On my CrazyBike2, the braking even using both motors at once is minimal; two typical 12FET controllers.
On SB Cruiser using 12FET that does active EABS braking, rather than just regen, it's really hard even though only the right motor is doing it. But this actually *uses* power to brake, rather than regenerating it back into the battery.
None of the controllers presently on either vehicle are programmable to change their regen settings, but some are.
As for pedalling and gears--that entirely depends on how you ride and what the front gearing is on the bike.
I use SS gearing on the rear of CB2 because I can't really pedal enough to do any real work moving it. In an emergency, if everything dies on there, I could pedal it a few yards at a time, stop and wait a (long) while, then continue, but it's easier on me to walk it home.
On the trike, it has SS gearing because it was too complicated to set it up for more than that when building it originally, as we were kind of in a hurry. :) Also, the way the rear frame is made it can only hold a singlespeed-setup wheel. I have a plan to add more gears to it for emergency pedal-home and possibly a middrive, but none of what I will do applies to a bike.
For someone interested in pedalling along with the motor or unpowered, there's not much reason to just use singlespeed other than simplicity of setup (no derailer, no shifter or cable, shorter chain, lighter weight by a little bit, etc).
For someone not interested in pedalling, there's not much reason *not* to go SS.
If there's no law requiring operable pedals, you could just leave the whole freewheel and chain and pedals off entirely, and just put pegs on the BB, if you really want to save weight. ;) Or leave the pedals so you can ghost pedal for whatever reason you might have for doing so, but remove the rest for simplicity and weight.
Personally, I'd rather have the pedals and chain all operable just so I can get back home without walking it, if I absolutely had to, though at this point on a heavy cargo bike I couldn't do it unless it was a trike or had outrigger wheels to hold it upright so I could go at really really slow speed and gear it way way down to not have to put so much torque into the pedals directly (which really hurts).
