X-Nitro said:I have the the new SMPro platinum rear hub here showing 133mm between spacer flanges, add 10mm for the brake anchor, another maybe 20mm each side to get thru the swingarm & chain adjusters. The spacer bore is 12mm.
X-Nitro said:Ok keep looking, but I'm not sure why you think axle thread or shoulder length specifies other dimensions.
I use the long axle and have 5mm thread extending clear. The combination of NTC disc guard and fat hub floating rotor requires an addnl 3mm spacer on the axle to clear button head disc mount bolts, bad on ntc design.
Hawaiiguy said:I have that disc guard and rotor,did you use the supplied disc screws( there purple),my friend reused the stock disc screws and had clearance problems,put on the supplied screws no problem.
Rix said:Nice fin, looks trick!![]()
Hawaiiguy said:Mine and my friends came with low profile purple screws that have clearance.My friend originally reused his stock bolts and had the same clearance problem.Both of our Luna rotor kits had the purple screws included .
Tommm said:Anyone tried shunting the stock controller? Thing has 36 fets...
fechter said:Sure enough, your magnet is messed up. And it has 10 poles.
It would be possible to make one from aluminum or plastic with some tiny cylinder magnets inserted into holes. You'd need to space the holes very precisely and make sure the magnets were inserted to exactly the same depth.
Here's someone who did something like that:
https://ukmars.org/2020/09/improving-the-pololu-magnetic-encoder-more-magnets/
Hard to say why it failed. Possibly it was rubbing against something and heated up enough to demagnetize that spot.
It would also be possible in theory to re-magnetize the spot, but that might be hard to get precise enough.
