beemac
casainho said:If you can, please try latest SDCC version. This bug is so strange...
I've just submitted a pull request for a few minor changes. It also 'works around' the assist level 3 problem by changing the way errors are counted. Even so for now it's recommended to avoid using any assist factor of 0.028 if you aren't using the temperature sensor. If for whatever reason you insist on using 0.028 for assist factor - then change the corresponding startup boost factor to something other than 0.028 and you'll be ok.
I also tested at 9600bps just in case - no change. One packet fails CRC - why only when the packet from the wireless controller contains the magic values I do not know. Once that packet fails CRC - there appear to be about 11 bytes that follow - and each causes an error because they are not 'start packet'.
I use the latest SDCC 4.0.7
