I just got it work
Upgrading firmware of the ST Link v2 dongle helped. You can do this by using ST Link Utility: STSW-LINK004 - STMicroelectronics
Thanks. Typically I cant get ST.com to send me a verification email !I just got it workUpgrading firmware of the ST Link v2 dongle helped. You can do this by using ST Link Utility: STSW-LINK004 - STMicroelectronics
yes 32. bit i have tried that several times no good.i have 32 bit sdcc could that be problemProbabilmente stai usando un sistema a 32 bit.
Prova a sostituire i file nella cartella /tools/cygwin/bin con quelli contenuti nel file bin_32.zip.
Have you replaced the files with those for 32 bit and it still doesn't work?
What operating system are you using
YES. Old laptop 32bit updated to windows 10. The visual programmer would read and write ok .I have now flashed osf using my desk top pc, Not very portable though.
FFS! Why is this stuff so janky.
Edit: got the emails 12 hrs later...
Are you sure that you don't have the newer controller version (sold only by enerprof as far as I know)?Obviously it still doesn't work, but new error message.
Don't know - bought from PSWPower in 2021Are you sure that you don't have the newer controller version (sold only by enerprof as far as I know)?
This should normally be the old flashable controller.bought from PSWPower in 2021
You need a complete wired connector, which isn't the case with a speedsensorcable. I don't know if the extension cable is completely wired...
Should I get an extension cable instead of a speed sensor? ....
Because of safety, the throttle function is linked to the brake option..... the throttle is greyed out ...
Same problem here, I have three different clones and an original st link.Got the firmware updated and tried again:
I've checked for continuity on all pins and its good. I've tried with 5v and 3.3v. I've tried with 2 different STlink V2's, the cables are as short as physically possible, the software is all installed exactly as required. I've tried with x4 and x6 in STVP
Error : Cannot communicate with the device !
Check the SWIM cable connection and check all the needed pin connections on the SWIM connector.
If the application code uses Swim Disable and Reset pin as Output or has disabled SWIM Clock Divider:
Try Now to SWITCH OFF and ON the application Power Supply while NRST Reset pin is forced low.
Error : < PROGRAM MEMORY reading failed.
Error : < Operation aborted.
I'm about ready to chuck this motor in the bin and pick up something else.
several picturesHi, can anybody help how to connect st link to tsdz2b, its only 3 pin speed sensor, so I just want to know the easiest way to flash this motor with originsl vcld5. Is still possible with this 3pin speed conector(and how to connect to st link) or I havevto use cabel to vcld5 to flash it?? Thanks for any help
