maximusdm said:
Did some more tests. I just installed the motor on a new MTB 29".
I am testing A7 with the default assistance levels.
I tested power mode because I wanted to see improvements form 0.19 first, at the moment only on flat city road.
Great!
Please try and configure to settings you feel fit your riding style!
maximusdm said:
1. Acceleration. Previously I used 8A/s and was very pleased. Now I am using 80 and seems to me a smaller acceleration.
@Buba can you please detail what is the corresponding between old mode and new one?
The acceleration is set mainly to not cause motor jitter at startup and reduce excessive strain that did not do much other than damage. This was the reason we could have premature failure of the blue gear and also accelerated wear. This is true for the metal gear as well.
The acceleration is much faster than before in all situations! Where it might feel "slower" (actually smoother) is during startups. If you press hard on the pedals you can easily get up to high power levels but there will not be a sudden power delivery so as not to strain the system.
But will of course look and see if there is anything I can improve for the Alpha 9, Maximusdm!
maximusdm said:
2. Startup boost does not work for me. Tested with 40-60-80 sensitivity. On flat this is nice to have, but on steep hill it is a must if you stoped and want to start with a 25kg bike. I think the problem here is that on old boost mode you could set a separate assistance level, but still I cannot feel no difference between 0 and 80.
There is no Startup Boost. Are you referring to
startup without pedal rotation? That is a parameter to enable assistance without pedal rotation. Higher values gives assistance with lower torque applied. If you were to set it to 100 % it would assist as soon it feels torque on the pedals.
Startup Boost is included in Power Assist, sort of. Power Assist has now a wider operating range and improved control theory. So it should assist more if you want it to.
If you are using more torque and low cadence you could try Torque Assist. Otherwise, configure the Power Assist after your personal preference and I think you will find something that fits you perfectly!
maximusdm said:
3.
Power delivery. On motor mode 0 (48 std) it is impossible to get 600W+ on flat with assistence 9 whatever you do. With mode 2 (48 HC) it is better, with my custom HC mode it is a BEAST! On 5 assist i get constant 800w+ at 45km/h, on huge MTB tires. With road tires i assume i can hit 50km/h with small effort. Obvious it is burning the battery but what is important is if you need speed, it can provide.
I think you really need to configure the settings. They are highly individual and depend completely on the torque sensor and user. If you do that I can guarantee that you will be able to reach any power level you wish!
maximusdm said:
One good thing in 18.2 and 19 was that it was possible to make the motor behave violent
. Starting with boost of 800W is
. Now even with 9 assist it is starting with 150w
Overall impression is a more powerful motor, but it delivers the power on a linear way with smaller angle and acceleration is slower. Can this be configured or it is possible only with software changes?
Again, try changing from the default values and you will see that there will be more power
:wink: It will be smoother than before but within limits of the TSDZ2.
maximusdm said:
Thank you for a detailed post and feedback!
