Sorry I don't have oscilloscope, but I measured with multi-meter and when the backlight is on on the LCD it's 6V on the green wire and 0V when it's off. I marked the connection on the controller.casainho said:About the lights, maybe they are controlled by PWM on PD4/TIM2_CH1. If this is true, this means we can have a good control of them, like maybe turn them at an higher, medium or zero value -- like at max value when we brake, medium for when lights are enabled, etc. I will be able to make configuration for the various options on LCD3.
Can someone please connect an oscilloscope to the lights wire and see if there is a square wave?? and if so, record the signal frequency and the duty_cycle?
Can someone please post pictures of the lights? I never saw them...
And, with the original LCD and firmware, does the lights have a max brightness when we brake??
PSWpower sell lights for tsdz2 Front Rear but I 'am using this wired directly to the battery and switched with a relay, and for the rear I use this connected to the tsdz2 with the speed sensor Y splitter cable
