casainho
- Joined
- Feb 14, 2011
- Messages
- 6,045
Good that your sensor works and you could validate it.jbalat said:I tried it with a 5v source and it seems to work. It went from +25mv to 100mv when I heated it up
So I am only getting 4.4v from the motor ? Perhaps I need to find another point or use a buck converter ?
So next step is to validate the wiring to the motor controller.
I can't say that 4.4V are not ok. Please make sure you are connecting/measuring to GND and 5V wires of the motor controller. You can try to wire the sensor to the motor controller but keep the output signal not wired and then validate again the output signal and if it works, finally connect to the throttle wire (make sure you are really connecting to throttle wire). Also then look at the ADC value of the throttle that is the raw value measured (5V equals to 255 value).
Also, I think the LM35 can work ok also with a voltage as low as 3.3V...
