fw ограничен, вам придется использовать модифицированную версию, чтобы обойти эту настройку, я знаю, потому что есть люди, которые продают ее на Facebo
fw is limited, you have to use a modified version of it to be able to bypass this setting, I know because there are people selling it on facebook
Thank you very much for answer)
When I tested earlier, electric braking (high brake used) was happening.
Currently I am away from that system, so can't 100% guarantee that regen brake is turned on, but the behavior as mentioned above leads me to believe it is on.
One of my tire is punctured ;), I mean a fracture in the leg, so can't test it soon. Hope to test it & give feedback at a later point of time after recovery.
BTW, are there any Votol app available from Vino?, I had earlier used fishblood's app available in this thread, but it was difficult to use in my setup.
Looking forward to hearing from you, with my homemade Bluetooth module, It works partially with the first blue app in the picture, of course most fields are not adjustable, but the monitor screen works very well, you can try it
can you show me how to connect the controller to that app, it cant detect my hc05 module
Anyone can say the name of the Bluetooth app? I don't find it in wechat 😅
  • 认证主体​
    个人开发者
  • 账号原始ID​
    gh_a636a3904e02
  • AppID​
    wx2dea5e1b573149cd
I use hc05 and the password is 1234, only read permission, not write permission.
I don't wechat, how can i try this app?, not seeing in Google playstore
Please create an account, it is not available on chplay or apk
Update: I have the flux weak disable and seem work good. The controller put me on 48km/h. Now I need to found a solution to cooling better the controller. After 10km, the temperature rise up to 90c. After a cooling solution, I try to play with flux parameter.
Anyone have any suggestion about flux parameter for:
52v lion 38.4a battery
EM30S controller
10inch hub motor, 1000w, 10 pole pair, 1300rpm rated.
Thanks
Hi!
Do you have the self learning bin archive for the EM 30S?
Thanks!
The em30 not have the learning function. You need to set manually all parameter and you need to know well you system( motor pole, angle of sensor etc.)
I've been trying to set up the EM50-4 for a few days. CAN version.
The controller has been working very strangely for the last two days.
Yesterday I could easily change the RPM speed.
Then, at some point, the RPM limit is activated.
I don't know how. I didn't specifically include anything that could limit the RPM.
But after that, no matter what RPM value I choose, the RPM on the display always shows no more than 600.
What is the problem I couldn't solve. Today I started trying to figure it out again.
It turned out that Speed ratio (%) is active and unchecked in the Speed limited enable window.
Although yesterday I freely changed RPM and the checkbox was unchecked. And I did not change the value 37 there.
Today, without checking the box, I simply changed the Speed ratio (%) value and this strange limitation disappeared. The motor spun as much as I wanted.
But literally after a few minutes of further adjustment, the RPM limiter became active again.
A one more thing I can't check the Speed ratio (%) box because the gear indicator and gear shifting disappear.
Ini file here. Config1711.ini
Thank you!
Bonjour les amies
J'habite en montagne, j'aimerais avoir plus de couple et de puissance pour rouler en montagne sans griller le contrôleur mdr
Y at-il une possibilité de faire évoluer le paramétrage de l'em150 ? Svp 🥺
Batterie supportée 220v max
Actuellement je monte une côte de 11% de dénivelé sur 4km à 90kmh
Pièces jointes
Hi at all.
Someone can explain me how to use the moving vehicle booster? If it's possible to configure a switch to enable/disable it?
Thanks
Bonjour les amies
Pièces jointes
what hub are you using? how many kw? and temp after your climb?
Hello guys,
I'm building an ebike with a QS138 and a Votol EM-150 controller(No CAN version).
Everything works fine but I would like to have more initial torque.
The problem is that I am not able to connect the controller to the pc.
I've searched in this thread and tried almost everything.
I tried with the original usb cable pl2303 HXA with nearly all drivers I found.
Then I bought another Usb cable PL2303GC but got the same message "communication abnormal, no response"
I also saw that maybe exchanging the TXD and RXD cables but no success.
Somebody can help me on that?
Is there any other cable or driver needed?
My old controllers had the reverse gear and the cruise control in one button - which makes sense, due to you would never use cruise control in reverse anyway. Unfortunately the Votol does not have this setting
Have you tried this? -Using the option "59:Ѳº½+µ¹³µ cruise_with_reverse" in the port settings
How so)) There is self-study, I have used it more than once in my EM-30S, fields are set manually, and the angle is determined after testing.
