kagemushablues
Hi everyone,
I'm new here! Making a build and wish to get some feedback from you witches and wizards.
(Currently I'm riding a Yamaha Cygnus (96v60Ah, 4kw qs motor, and fardriver 96400). Not a total noob but still lots to learn.)
Build is a Honda VFR400 NC21, good'ol delta box frame.
Specs:
Motor - 10kw Golden Motor (but looking at 15kw and 20kw options, more on this below). (17kg to 40kg)
Controller - APT 961000 - 600A/1000A (10kg)
Battery - WeLion semi-solid state 111ah x 28 x 2 - 96v 222ah 3C. (68kg)
BMS - 2x BMS to hit that sweet 96v x 600A output, as well as fast charging.
Questions:
So far I've owned the APT 961000 controller for many years but haven't used it. Need to put it on something. Luckily the Golden Motors don't require encoder controller so we're in business.
Any experience with Golden Motors - I'd LOVE to hear your experience with them!! Thank you!!!!
ALSO --- Has anyone ever used a swingarm pivot as a jackshaft? I've seen it on trikes/go-karts, but not on motorcycles. Thanks!
Specs:
Questions:
- Swingarm mounted motor. It's been done and was wondering what everyone's experience is?
It'll be a custom swingarm and added a mount
- If motor is mounted to chassis, I'm able to use the higher powered ones with water cooling. Please see v2 pic below... Would the center of gravity be too high in this position?
This would also be a dual-shock setup. Not sure if the rear subframe can take the forces?
- Most importantly... Can the APT 961000 even drive the 15kw / 20kw motors capably?
Talking to Golden Motor, I've learned that:
- 10kw motor can hit 18kw peak, but in a split second burst can hit 22kw.
- 15kw motor can hit 22kw peak, burst 30kw, and can take up to 50kw.
- 20kw motor can hit 28kw peak, burst can take 50kw, not sure how much it can take.
(the 20kw is better for a car conversion to be honest. Too big and wayy too much power).
- Target power - Horsepower vs watts.
I ride two-up most of the time and need it for commute + touring.
Desired top speed: 88mph is good enough!
Most likely 20kw motor is too high spec for me... Aiming for something between a Honda Rebel 300 but closer to 500.
I.e. 33 horsepower would be ideal. Likely 10kw/15kw motor is best but wish to confirm design is good before committing to water cooling.
