TommyCat
Power poster
That sounds much better.
The anticipation is building!
Took advantage of a window of no rain, got back from an 8 mile ride with no throttle problems. At 20% throttle engagement setting with the pot, launch from a stop is much smoother than the previous default setting of 30%.That sounds much better.
The anticipation is building!![]()
As opposed to not being able to reapply throttle after slowing down and still moving only?It now happens from a dead stop.
No regen. Battery voltage not spiking up during braking per bluetooth bms app.Does your bike have regen? Is it possible the battery voltage is spiking up during braking?
Correct!As opposed to not being able to reapply throttle after slowing down and still moving only?
I have it set to engage motor at 10%. I may increase it a little (to 15%) since it is a bit sensitive at 10%. I am getting full range on throttle twist with gradual power up down.Sounds like you have the throttle dialed in nicely. When it's working, is it working well. I.E. Full range on the throttle twist, with nice gradual power up and down with minimal deadbands?
Your description of throttle behavior is correct (when it occurs, which is about 3 % of the time). It does not matter if I let spring return to home or add back pressure by hand to reset to get power. Either one gets the bike to move again.Can you describe in more detail the reset procedure? Your throttle automatically returns to home by spring return. And when you power up nothing happens. But when you purposely return the throttle to home position. Do you have to put a little back pressure after reaching the home position. Does this make anything on or near the throttle move or twist? When you had your voltmeter hooked up and taking readings, did it change during this resetting procedure? Did you try this test?
No I have not. On the controller with the dead speedo which I had opened, I recall checking the error LED with an ohmmeter and got good readings, also measured the current limiting resistor in series with the LED.Have you verified that the controller's error LED actually functions? Have a blink or on steady during power up? Will it set a code when you unplug the motor, or something similar that you know sets a code and is easy to do...
I see you have malfunction indicator lights on your bikes front panel, but no mention of them working...?
Probably the controller's throttle over voltage safety working... may or may not set the throttle error indicator.Yesterday, with bike on center stand, I cut the pot out of the circuit. Turned key on, expecting full throttle but not so, wheel did not spin at all!
Sorry, it did not occur to me to look at the controller LED (which has never lit every time I looked for it).When the error light on the display was on, did the controller also give the controller's LED a flashing code?
With the battery disconnected, and the throttle disconnected up close to it as possible in order to get good resistance readings.
What are the resistance values from the throttle ground harness connection to battery negative?
And from the throttle signal harness connection to battery negative? For comparison, my controller has a signal resistance of 13.31 K ohms.
In your travels, did the deadband between throttle's Home position and motor start up ever vary with nothing being changed?
If this also means operation is good, I'd walk away carefully and slowly and leave everything as it is.Since restoring the throttle to factory config, the throttle error light on the display has not returned.
There were 2 separate throttle issues.If this also means operation is good, I'd walk away carefully and slowly and leave everything as it is.
No need for resistance checks now if all is well.
I've ran continuity checks on all pertinent wires and connector pins (pristine with no damage). Bike never seen rain = no corrosion. I've tried another controller and another throttle, neither helped. I think the 60V controller just do not like being run at 72V and doing the strange things I've been seeing.I just get a feeling that there is an intermittent wire connection or bad wire in the throttle wiring. Between the throttle's hall sensor
legs and the controller's PCB board.
Thanks for the suggestion. I've had the controller opened multiple times to inspect it. All solder joints and wire terminations looked fine.I've seen bad solder joints on the controller board where the wires attach before. May be worth looking inside.
This is why I suspect wiring or a connector in the cable throttle wiring.I've tried another controller
I have also checked the pertinent wiring and connectors. I don't think there is anything that can be done to fix it other than a new controller that can handle the higher voltage that it's operating on. Thanks for all the help you've provided TC.This is why I suspect wiring or a connector in the cable throttle wiring.
