Hang the (inanimate) load from the pedal instead of putting it on top of the pedal.But seems difficult yes because pedal is small
did basic methode (noweight then rider weight.) it works fine like this no need more complicated!Hang the (inanimate) load from the pedal instead of putting it on top of the pedal.![]()
There is no canbus version of Tongsheng......
Is there a can bus version of OSF? Could not find info on this?
If you have already done the calibration by entering the values ofI'm not really understanding everything you wrote. Thanks for trying. If you can tell me step by step what I need to do to improve human pedal power reading accuracy, I'd appreciate that. If not, I am happy the way human pedal power behaves as is.
Rode the bike to get lunch today and got to 58 miles on the odo, 39.5V. Never reached that high a mileage before (48V 6 Ah battery). Usually 30 to 40 miles (on higher assist levels).
The latest version for LCD3 is the one you find in signature v20.1C.4-3-LCD3, there are no further versions and there will be no further versions.Hello, thanks for all informations
Last week i install osf for kt lcd3 to tsdz2 board and lcd3. I observe lcd3 works fine, i made battery motor setups than shows battery voltage, adc values, torque values...But in every mode, motor and lights never work, also walk assistant not working, i know my controller card is ok, i tried orginal firmware, everything is working, can anyone help me,, want to use osf..thanks
Yes it's true, the assistance levels in cadence mode use about half of the available scale, even less if you set the maximum power to 290W.Question for cadence mode.
Hello i know i'm playing a lot with code and settings but i have a question on original code.
So my Firmware here is original (from mbrusa) and not modified.
for me Assistance in cadence saturate when at level 100 in setting.
To have progression in level i had to set lvl to 10 / 25 /50 / 254 (max for turbo)
My power is limited to 290W (norme EU let a margin of 1.115 from electric power to shaft of motor and real efficiency of motor is less of 0.85 but that's not the point).
When i check power on LCD at 100 of assistance i am at 290W. At 50 i'm not, it's less (normal). If i am level 254 i got 290W too (normal, it is saturated by battery max current).
I understand how is calculated torque_delta from RPM and assistance lvl, code is clear on this point.
Why this choice to saturate assistance near 100?
Why leaving 100 to 254 in a same level ? why not reparting all power between 0 and 254 (by for example adding battery_current_limit=battery_current_max*levelofassistance/levelofassistancemax ?)
I know torque calculation change (from a constant: the level of assistance)... but what i find strange is in default 36V settings, level 2 is 100 in cadence mode.
so default 36V give 250W nominal (290W) at level 2 and other mode give no gain of power?
Torque calculation from RPM is altered but why not altering max power too to get less current and preserve battery in lower level?
thanks
The best mode is Power assist, especially for gravel bikes and mountain bikes.Hi. I've converted a Felt Broam gravel bike to a TSDZ2B 36v 540wh battery with vlcd6 display. I'd like to ask what would be the best OSF configuration for the Gravel - hybrid mode? What mode would be optimal? Of course I'm not interested in speed and power limits.
I have done the first 2 items for sure. Pretty sure I also have 3.0=1 "calibrated" enabled. Just to be sure, I powered up the system to check but was met with a frozen display (see photo) where none of the 3 buttons work (pwr, up, dn). Throttle does not work either and there is no assist. Cannot change modes, assist levels etc. Long press of power button does not power display off.If you have already done the calibration by entering the values of
"Pedal torque ADC offset" (without weight) in 10.9 and "Pedal torque ADC max" (with your weight) in 10.10, also 3.0 = 1 "Calibrated" enabled.
That's enough.
Cadence is good for bike vehicule to go to work: you can make effort or not as you want. If you are sick you can use your bike without effort pushing up assistance.Yes it's true, the assistance levels in cadence mode use about half of the available scale, even less if you set the maximum power to 290W.
It's not a choice, it's a consequence of a quick modification.
You should know that from version 20-beta-1 where I started up to my previous version, with the assistance levels you set the duty cycle, whose maximum value reaches 255.
I didn't like the assistance, as the cadence increased the power decreased, but I never worried about this, because I considered it an emergency mode in case of a fault with the torque sensor.
With version v20.1C.6x I changed, the assistance levels set the current.
The modification seems to work well, certainly better than previous versions.
I used the raw adc value to avoid exceeding 255 by adding the proportional quota to the cadence.
But I can do differently and use the levels scale up to 255 as you pointed out.
I added it to the long list of things to do.
With boost... lot of possibilities and really natural feeling. You shall calibrate torque sensor-basic way-. Power will work very well.The best mode is Power assist, especially for gravel bikes and mountain bikes.
Same thing happened a few days ago but somehow it resolved itself (I do not remember how or what I did). Now it seems to be stuck permanently. I've tried powering down the battery which shuts off the display. If I power up battery and display, it gets stuck on that page again.
Ay idea what caused this? Any suggestions on things to try to restore operation?
Motor has 1300 miles problem free till now.
Edit: Problems solved! The magnet on the brake cutout slowly went out of adjustment from adjusting brake cable. When brake cutout is enabled during power up, that's the display that comes up.
edit: repositioned magnet with DS foam tape and it's back to normal.
edit: Verified 3.0=1 "calibrated" is enabled
... bricked? No way to flash it ?Hi mbrusa,
I am curious:
Is freezing the system when powering up with brake signal active intended or is that a bug? My TSDZ2 would have been bricked if I was not able to find the cause.
I'm running V20.1C.4-LCD3-update 3, 3/30/24. Interesting your's behaves differently!I am running one bike with the v20.1.C.2-update3 from April 2024 with a VLDC5. The other one is even earlier. I can power up with brakes active, If I power up with throttle on, bike takes off. I believe your software dares back to LCD3 days?
I did not try re-flashing it. Even if I did, it probably would not have fixed the problem unless the brake active signal is cleared. Bike would have no assist = bricked.... bricked? No way to flash it ?
Is it software or hardware problem? Disconnecting brake sensor doesn't fix the problem ?I did not try re-flashing it. Even if I did, it probably would not have fixed the problem unless the brake active signal is cleared. Bike would have no assist = bricked.
It seems like DZ40/41 displays are not really supported in the OSF Firmware unless I missed something.Hello,
I wanted to ask what is your experience with displays DZ40 and DZ41? I have DZ41 on tsdz2b with osf and seems to function, but allways shows error code.
It is a hardware feature of the TSDZ2 controller.Hi mbrusa,
I am curious:
Yes, I do not recommend using version v20.1C.2-update-2 or earlier and, if possible, I recommend updating to the latest version.Hi,
I'm encountering E04 (blocked motor) and have no support at all when pedaling. When using walk assist (enabled in hidden menu, pressing "-" for three seconds), sometimes there is a slight movement of the motor, but usually nothing.
I'm running OSF since 2.5 years (v20.1C.2-update-1) with no issues whatsoever. Today, during my commute, assist was intermittent and E04 appeared. The motor was rather warm to the touch (15 C outside temperature), but I seldom check the motor temperature so I cannot say if this is something unusual.
I'm not sure how to debug this further. I saw now there is a notice on github not to use v20.1C.2-update-2 or earlier releases. This worries me. Is my motor fried?
I wrote that for me, the cadence mode is an emergency mode, but I don't mean that it should be for everyone.Cadence is good for bike vehicule to go to work: you can make effort or not as you want. If you are sick you can use your bike without effort pushing up assistance.
So you shouldn't consider it an emergency mode. It's just totally different.
The main problem is that max power reached isn't stable with battery voltage. It calculate a current.
we should maybe add a correction depending on battery voltage to maintain electric power as battery voltage decrease... (proportional).
I didn't well understood what you mean for the changes you made.
Setting assistance to 254 give you a function current=f(rpm) which goes faster to saturation (max battery intensity) than for example assistance at 100?
I assume maybe the phenomenal is amplified by the fact I have high rpm (80 110) )?
at lvl 10 (eco) I got up to 160w (bike doesn't accelerate like dumb but power is enough for an every day bike).
It's allready a little high and I use only 10/254 of capacity of setting of assistance.
Yes, the motor/bike works as if the battery is empty. I can pedal without issues and the motor makes no noise. Just before the assistance stopped working (a few seconds before), I felt/heard slightly increased vibrations/noise from the motor, higher than usual but no grinding or cracking that would indicate something breaking inside. I thought maybe the hall/torque sensor is broken, but walk assist doesn't work either. Does that exclude a broken hall/torque sensor?Yes, I do not recommend using version v20.1C.2-update-2 or earlier and, if possible, I recommend updating to the latest version.
But if you have not had any problems in 2.5 years, don't worry. Nothing is happening.
From what you wrote, E04 is the consequence of a mechanical problem with the motor. Difficult to identify the cause without disassembling it.
Is the bike pedalable with the motor off?
