Well that was silly of me not to include it. Here it is:Allex said:So where are your Profiles screen? We need to look at it.
Played a bit with PWR timing, but no difference...I don't think that's the problem as I'll explain.
I'm running RC9G_4.Ohbse said:What firmware are you running? Apologies if you already mentioned it.
Yeah, I realize that. This is my old Stealth Fighter LifeP04 battery with over 500 cycles on it. I'm just using it till I can save up for a new 18650 pack.Ohbse said:You really need to get a new battery though, that level of sag means you're hitting it pretty damn hard and it's probably getting pretty toasty and further shortening its remaining life. Not to mention the sweet spot for high power on a mini-e or any other controller with 100v FETs is about 80v/20s
So back to my issue, I think I've discovered another key piece of information that's really strange. With the above profile settings, Eco mode works well and as expected, accelerating nicely and topping out at about 40kph. However in Normal and Boost modes, I get great acceleration up till 25kph where it just stops accelerating and sits at 25kph without going any faster. I can't find any settings that might be causing it to do this.
The only one I can think of is the speed ratio, which is currently set to about 83. What should it be set to for a 24" wheel?
Anyone got any idea's? I'm hoping it's really obvious, and I'm just blind.
Cheers
