I started working on a way to mechanically test for the flux in the gap, but it gets very involved, and the results are still
going to be somewhat questionable, so I can't see going through all the effort.
What I really need is a calibrated Gaussmeter, plain and simple. If I'm dealing with building magnetic circuits, then I'm
always going to need to know what the actual Teslas are.
Looking around for a cheaper unit that will fit the bill, the top pick so far is the TD 8620, with probe, good for up to 20K
Gauss, or 2T, and has a 1mm thick sensor that will fit into most gaps. I saw a Youtube that Doctorbass made on it, and the
unit seems to work fairly well,.. so I'm about ready to pop for one unless somebody has any contrary info. ($90.)
Looks like it will do what I need.
https://www.youtube.com/watch?v=kiDKh_-M3bA
Meanwhile, I checked the magnets the old fashion way, using a screwdriver, and noticed that a lot of the magnets are not
up to snuff, I have strong ones, and weak ones, which is not good. Looks like my DYI magnet cutting has turned out badly,
and Larsb was right, I should have just bought some custom ones.
(I still want to try the water jet though)
The T meter will tell exactly whats going on there, but I'm thinking I might have found another good reason for a possible
weak magnetic circuit.
I'm still going to go ahead with the narrower gap, tweaks and tests with the way it is, but I'm starting to formulate a plan
to maybe double down on these rotors, which are too thin, too weak, and two piece.
The idea is to make new rotors with 1/4" one piece steel plate, and use some of the giant 6mm thick wedge magnets that
I found a while back, in a 16P number, instead of the 20P I have now.
https://www.magnet4sale.com/n42-wedge-neodymium-magnet-od8xid4x0-25-22-5-degree/
The big magnets are a little longer than the cores, and will have a 5mm overhang over the end windings, but from what I've
read, some overhang is a good thing... for fringe flux, and hook up.
Thicker back iron, and 1.32T magnets would certainly step up the circuit,.. eliminate any rotor flex, and should get us
closer to seeing if this SMC has a chance. 16P will make it run faster, but it's the SMC's performance that needs to be known.
I drew up the set up in CAD to show what it might look like, a front view to see the size differences, and a side view for
the thicknesses. Let me know if I'm missing something or on the wrong track with this idea.
(Quick drawing's are not perfect, but pretty close,.. I'll do a better one if the idea is viable.)
