If the axles are not flattened then the axle should be the correct diameter to fit into the wheel slot. So if we remove some material, we now need rectangular shims..
Well, luckily the design is not as such
Keyde will sell you a predrilled hub with spoke counts in units of 4
I agree that i should go tubeless compatible with the rim... maybe even use that capability
Also been sleeping on this motor for a long time.. Keyde published scant details until recently.. and also they were asking ~$700 for just the motor until now. That cost is still high for a Chinese designed and produced motor but maybe they will surprise us with 0.27mm lams inside / some decent build quality, idk.
I'm willing to risk it for the brisket and buy a front p100 and do a partial / full teardown once i get the battery situation sorted. More news on this later.
