My new 18 FET TO-247 layout riding video page 10
Any thoughts on the the gate to source signal while the MOSFET is pushing such high currents? It looks surprisingly clean compared to some other setups I've tested at much lower currents.
Suggestions on other things to check? before I progress further. It's looking good to me so far, but I don't want to have a false sense that it's working well.
Everything looks beautiful to me, with the exception of the weird ringing noise that is hopefully just instrumentation artifact, but that may be close to the real waveform.
Tested again last night from 100-850a, that ring was not there and I couldn't reproduce it. Best I got was a small bump at turn off and it too was dependent on scope lead position.
That waveform is taken across the shunt. Last night I tried to replicate it best I could and then watched drain to source and gate to source, it didn't show up.
850A sounds really nice! :) I'm so excited for your controller!! Serious ebike hotrodding potential there my friend. You should be able to torque saturate a cromotor anytime with that beast!
Well, my goal is to get it up and running. I'd like to come visit you so we can torture test 2 of my designs and collect some real data so I can get a sense of what these designs can do.
I realize the tests I just did are only single pulse, but I'm really surprised by how clean the G-S is at some silly high amps. The difference between my first design scope shots and then these is pretty drastic and I'm running 5-10x the current pulses I was on the previous tests.
If this can burst 400A for 2-3 seconds I'll be pretty happy. I really want to know what it's continuous rating is vs what it can be burst to. I don't think I've found any info on this because it's not a common engineering practice. Normally an inverter (a good one) is designed to operate at continuous spec for 10-20yrs. Burst current rating is something the DIY and vehicle world seems to have invented.
zombiess said:
I really want to know what it's continuous rating is vs what it can be burst to. I don't think I've found any info on this because it's not a common engineering practice. .
I think this is because there is truly an infinite number of variables that can cause you to not achieve the limits. SO consider it a challenge to hit peaks as close to the data sheet says ;)
Here is some additional testing that I performed today. It's not too exciting, but it does demonstrate how important it is to understand your test equipment and it's limitations. Common Mode noise picked up by the probe leads can make you think there is an issue where one does not exist. I figured I'd have a difficult time making measurements with high current pulse tests due to the coil radiating EM like a weapon, so I took some time to try and study it.
This is the common mode noise reading of a regular probe (yellow) and a differential probe all connected to the exact same spot to measure the common mode noise from the 5uH coil. Air coils radiate wildly.
This is showing the CM at 650A from a 64v supply. As can be seen, even the differential probe lead is picking up a good amount of CM. After taking this reading, the scope was set with each input to ground while the pulses were conducting to verify that it is indeed CM noise and not real noise being picked up on the driver circuit. That test passed 100% with zero visiable noise even at the most sensitive scales. As can be seen, the differential has slightly less CM in the sine signal (400mV scale vs 500mV scale) and throughout the rest of the trace the switching noise form a nearby SMPS is not visible, it is fully rejected as is expected from this type of probe.
Probe used is a Tektronix P6045 with amplifier and no 10x reducer. Setup procedure was completed and the warm up time of 30 mins allowed for everything to settle. The blue trace is the differential probe on channel 2 in 1x mode set for 200mV per division, scope configured for a 2x probe to make voltage readings accurate. Scope was configured for 20Mhz bandwidth limiting and normal capture. Connection was made with a 50 ohm cable running to a 50 ohm terminator since the scope, a Rigol DS2072 only has 1M inputs. For future readings any time this signal appears it has to be noted as not real and due to CM picked up by the measurement instrumentation.
This test was done at 650A with all probes shorted and connected to the high side MOSFET source. High side was powered on but held low to make sure the miller clamp was active.
Measurement of the G-S pins of the high side MOSFET (non switched, only low side was switched in this testing) showing a
Zoomed in view of the G-S signal using the differential probe on the high side MOSFET (blue trace). Yellow trace shows the CMRR picked up by the passive probe when connected to the high side source. Removing the probe connection has no effect on the blue trace of channel B. Small pulses on yellow trace show switching noise from a nearby SMPS buck converter.
400a at 31v, 740mV of CMRR is present.
Reality of the noise is 740mV - 672mV of CM = ~68mV of noise on the high side G-S
This shows the full 200uS pulse width discharging, yellow trace is still measuring probe/lead CM. The same 740mV spike from the above picture is still visible, but it is only common mode noise and not actually present on the gate driver.
Same as above initial test, but the current has now been increased to 650A at 64v. As can be seen the CM is now 1.256V. If this was real there is a significant concern that a MOSFET might be turned on due to miller effect which would lead to a shoot through event.
This test shows more induced Voltage D-S. The real G-S noise being picked up by the opposite gate driver is 1.256 - 672 = 584mV on the G-S with a 650A pulse
650A, 64v test for 200uS. CMRR needs to be removed to find the real noise level on the G-S of the other sides inverter. The true turn on peak was not located, but the CMRR on a 650A pulse is 1.256v. This leads me to believe the only miller effect voltage being generated is maybe in the 100mV range which is significantly below the VGSth spec of the IRFP4568 MOSFET which is 3.0V.
Testing of the digital side as also done to look for noise. Only the common mode noise was visible. The common mode noise nicely shows the delay between the digital signal and the actual switch event at the MOSFET. Channel had it's probe lead and tip shorted on the high side source. Ground clip from differential probe went to this same location to keep ground references the same. The digital output was then measured using the differential probe with a 100X adaptor on it. As een below, the digital input is a 4.4 signal to the optocoupler. The ringing noise denotes the D-S switch of the MOSFET bank under test, this is not real on the digital side.
Zoomed in view of the propagation delay caused by the gate driver circuit. This demonstrates the digital signal being issued and then no output on the D-S happening for 1.32uS which is the amount of propagation delay in the gate driver. Yellow trace is once again measuring CM.
Preliminary Thoughts:
The experimental layout of 2 parallel buss bars run down the center vs a laminated setup, using internal shielding of the opposite bus polarity on an inner layer appears to significantly reduce the noise picked up by the gate drivers during high current. Common mode noise is a major issue when measuring as one has to filter out false noise from real noise. The above pictures shows +8v of noise on the digital side which does not really exist on the output of the pulse generate. This is all noise picked up In the scope leads.
Shoot through protection happens in ~4.7 uS which has been saving the MOSFETs while I torture test them. I have seen spikes as high as 5kA during direct short circuit testing while verifying desat works as expected (5.1 zener allowed current to go much too high). It did not initially due to using a 5.1v Zener Diode. The 6 of these were later exchanged for 5.6v zeners which reduced the trip current from 1.2kA to a more reasonable 725A at 25C. Target goal is 300A phase, but I would like to push this harder and try for 350-400A for short bursts such as dead stop accleration.
During all testing so far the inverter is looking to have very clean signals. I have developed an even better way to create a true laminated bus bar for the power feed which is something this design lacks, but instead has an alternative approach that still allows for the cancelation of large transients on the bus.
At this point I am going to consider my bench testing complete and move on to finishing up the wiring required to hook this up and have it work with a given brain board. In this case it will be Lebowskis chip. Pending success of this controller, I will scale up to more MOSFETs in parallel to continue testing high current controllers.
If this controller success under testing conditions, I will considering moving up to try very high currents for a controller along with improvements to the layout for minimizing noise.
Can u clarify? Two diff probe leads were connected to the same single lication?, I.e probe leads are basically shorted together while simultaneously touching one spot? I dont care about the regular probe leads cause they should never be used on gate driver side.
What makes u think common mode is not real noise? I think I just read wrong but just in case common mode noise is real noise, what you need to know is whether you have in your circuit or not. In fact we expect a lot of this type if noise in a gate driver but it's ok cause we design for it.
Made a dumb move, got the differential probe too close to the pulsing coil while in operation... EMP. Oops.
Good thing I have 2 of these and I only paid $100 for each one.
HH, my noise issue is those pictures is probably over exaggerated. I should have disconnected the passive probe before making the measurements to prevent noise from coming through the ground. Just did a check on my digital side with the other probe and nothing else connected and there is just a tiny blip of noise, not the monsters seen in my previous screen shots. I'll retest later today... and keep my probe away from the radiating coil.
Used my other probe and gathered data at 600A and 160a. I'll write it up and post tomorrow. Much different than the post with pics I just made. I think the probe I was using might have been wonky (or I killed it while learning a while ago), this one is newer and is rejecting the noise, even in the same type of configuration.
was it your diff probe that died, or the regular one? regular one i would expect to die after the way it was used (your lucky your oscilliscope is OK). diff probe should have survived easily assuming it is 1000V rated (typical).
by the way, one time when developing real high power swithching motor drive i had such bad time with tektronic diff probes i had to cut the leads to 6" long, twisted and solder the probe ends direct to the board. the lab manager was not happy i ruined his $1000 probe. for me, i put them in my tool box and used them exclusively for all future builds. was a pain to have to solder to the board the probe leads, but it was the only way to avoid all the crappy probe ends that are barely clipped on with spring loaded mechanical.. i.e. all stuff that oscillates under high energy high frequency switching.
My diff probe died, passive is A-OK (as far as passives go which I'm quickly learning is about as far as you can throw them in noisy transient environments).
The differential that died only has a 25V rated P-P input unless the 10x attenuator is used, then it's 250. These are some OLD school Tek P6046 probes (made from 1968-1997) but they are rated out to 100mhz (with caveats of course). The one that died was from the 70s. The one I'm using now is newer judging by the case design changes. I haven't really tried to date it. I don't know for sure what killed it but it died without being placed in circuit and it was right next to the coil field when it quit, so I'm guessing it might have been EMP.
As long as I continue to do this I will be investing in a good newer used differential. Do you remember what model you use to use?
I have been wondering about the spring clip connections and them causing noise. Dissimilar metals, mechanical interfaces, seems sketchy for precision work.
generally you don't need precision for this type of work. i just did cause i had special application and then after that i might as well have kept using the adapted probe. everything is Tektronic brand except for when you need detail in x-axis then its Yokagowa. it's expensive stuff, outside of DIY league. the scope is $50K.
I've never striped a probe, but I have soldered the GND springs to PCB on a few occasions, more because of the mechanical stability. Still haven't found probe to PCB adapters.
These are my shots done with 160A with 11v bus through a 5uH load coil. Test setup was low side triggering, high side gate driver was powered on, but input signal grounded. Differential probe was used unless noted.
DC bus voltage sag
DC bus voltage sag
Low side gate to source shots 200uS
Low side gate to source on
Low side gate to source off
High side gate to source low side turn on miller effect
High side gate to source low side turn off miller effect
Shunt reading with passive probe
These shots were taken at 600a, same test setup. Low side gate/MOSFETs triggered, high side gate drive had input grounded off.
Not sure what is going on here. This is the probe, floating, not connected to anything. At 600a this is what the probe is picking up. I also looked at it at 160a, and it was much smaller. Guesses? I'm thinking the probe cable is picking up the noise, not the probe tip.
passive probe showing 600a passing through it
Low side gate to source 200us (same noise as the floating probe in the first picture)
low side gate to source on
low side gate to source off
low side drain to source on, 200uS, crazy ringing
low side drain to source turn on
high side drain to source (diode) 200uS
high side drain to source turn on (diode)
high side drain to source turn off (diode)
high side gate to source 200uS miller effect, more ringing
high side gate to source turn on miller effect
high side gate to source turn off miller effect, what's going on with the negative voltage? Real/false noise?
Floor is now open for opinions, what do you think about the signals on my layout?
Should I move my air coil load 2m away from the DUT to minimize the effects of its radiation? This way I could better isolate the inverter. In real life the inverter is in an alum enclosure and the motor is typically in some sort of housing that shields it.
I wonder how much I am fighting the radiating coil? Might be a good test to see the delta in the same measurements for worst case as above vs closer to reality?
160A with 11v bus
never test a mosfet with the D/S voltage less than the gate driver voltage. increase your voltage to >=30V and repost.
HighHopes said:
160A with 11v bus
Thanks HH. I forgot you had previosly told me about that. What about all of my scope shots done at 42v 600a in the post directly above yours?
What about the air coils relative position wrt the unenclosed inverter? Should I enclose the coil to shield the radiation? Maybe just move it further away?
Testing is just as important as design. I don't have a solid testing/measuring procedure yet. I need some basic guidelines so that I can repeat them on future designs to see what may have improved or worsened. I am taking notes for future reference and have been referring back to my notes on the first design to compare, I am trying to replicate the same setup but am also learning as I go.
I usually use a motor in my tests, around 1m away from the working area. I think you're absolutely right in that the test conditions must be exactly the same so that you can do comparisons. You're measuring with the GND spring (if using a non-diff probe) and probing directly at the FET's pins, right?
(best photo I have of it, but you know, and there are others around)
Notice that, of course, when probing the high side FETs you need to keep in mind the reference point; that is, if using non-diff probe either the scope or the controller must float (yes, because you need to measure directly at the FET pins, meaning both probe tip and probe GND connection) and beware where you stick other probes GND lead.
I've also seen in my scope, that an unused probe connected to another scope channel, even if the channel is off and even if the probe has no GND lead, it picks up interference that you'll see on the channel being used. So, any unused probe should be disconnected from the scope.
I have a few comments, but you must keep in mind that my experience is at a much lower current and lower voltage, and that therefore I'm going to avoid to make "value" statements, so I'm just comparing to what I've seen on my experiences.
"passive probe showing 600a passing through it" [A is the correct unit]
It's a curve. The LR constant is too small, it's unable to keep current linear in your test. Is this bad/relevant? I don't know.
"low side gate to source on"
Looks just like what I usually see, such as in the double pulse test here: http://endless-sphere.com/forums/viewtopic.php?f=30&t=63983 (notice the pulse is 1st OFF then ON):
"low side gate to source off"
Never seen such convoluted turn off before, but hey, it's turning off a lot of current.
"low side drain to source on, 200uS, crazy ringing"
I'm not seeing how does it start at 0V, goes negative to -35V but then rests at -11V (why resting at 11)?...
For ground leads I've tried both on the passive probes. Tough to get those tiny spring clips to stay put or even the leads aligator with it's long loop which loves to pick up noise.
Thanks for the correction on the unit. Sometimes when I'm in a hurry to get notes down I skip case, but I actually had wondered if the abbreviation case matters. I refer to it as 600a because that's the peak value going through it. I'd have to calculate the RMS value which the math function can do, I saw a video on that somewhere. If I tried to put 600 A through these 3 MOSFETs for more than a few mS they would probably die. I've been using the 5uH coil I have because I'm trying to cause high di/dt to see how it performs under extreme conditions. I'm pushing it much harder than I plan to operate it at. Just experimenting really, this is very educational for me.
I need to reprogram my PIC signal generator so one pin does double pulse.
Yeah, this is wonky but that bump is directly tied to the amount of current. It's happening after the miller plateau. Not sure if it's real, the coil radiating and the gate driver and or the probe lead picking up noise or what. I need to experiment some more with this and the first step will be to move the coil further away to see if it effects it.
I'm AC coupled on the probe in that shot. These old probes have a bit of offset in them which is normal from what I've read. I use AC coupling after setting it up to get more accurate readings by eliminating the small offset. The -11 is because the bus sags big time after a 600 A discharge, need more caps :) So the signal in the scope picture is a delta from the bus which is actually 42V. These probes don't read accurately over 15V I think when I played around with them. Both did the same things, so did the amps. This probe is really for low voltage use. I'm using mainly to get a better picture of what's happening vs making accurate measurements of voltage. My passive probes stand no chance of getting a clean signal.
i don't mind typing it all out step by step, but it would take more time than i can give at the moment.
testing i a lot like designing. it takes time to think it out, make sure you know what your'e doing before you do it. there are rules to the game that have to be followed and until someone tells you, you'll never know them. they not written down anywhere. not yet anyway.
I sometimes just solder the GND spring tip to the PCB, helps alot :) . I also solder small pieces of wire (<1/2inch) at points I'll want to test. Next project I'll definetelly have more appropriate test points designed into the PCB.
Well, s is not S :) . s = second, S = Siemens .
I keep coming back to my 1st (and only) controller for tests and just keep learning.
testing i a lot like designing. it takes time to think it out, make sure you know what you're doing before you do it. there are rules to the game that have to be followed and until someone tells you, you'll never know them. they not written down anywhere. not yet anyway.
The more I talk to people like yourself who work in this type of EE field and look for texts on how to do things, the more I start to think I'm trying to join a secret club. I don't mean that in a bad way as many in this club have been sharing information with me freely. It just seems like there are few people doing it and I'm pretty sure it's because it's so difficult (with little good documentation) and one can do easier things and make the same pay.
One thing I noticed today that is particularly interesting to me is this thread. There are only a few of us posting to it, but the scope pictures I posted on Sunday have been viewed >250 times and the ones I posted last night are almost at 100. The very first picture in this thread > 1900 times, the schematic >100 times and the KiCad files > 50 times. I believe more than just the few of us posting are reading.
Hope everyone reading is having fun learning as I progress.
