chas58
good question...
leelorr said:The first link you posted, to Pswpower, is to a model that requires a custom frame. It can not really be used to easily convert an existing bicycle...
RTIII said:Hi All,
As an aside, I've searched reasonably hard but have never yet found the Tongsheng corporate web site - who doesn't have one these days?
RT
RTIII said:Hi All,
...While Biktrix advertises it as a "48V, 53v", "500W / 700W" product:
https://www.biktrix.com/products/tongsheng-tsdz2-torque-sensored-diy-ebike-mid-$
RT
THANK YOU SO MUCH!Steu851 said:RTIII said:Hi All,
RT
http://www.tsbicycle.net/
Sent usingTapatalk
Maybe they are talking about the throttle kit add-on. That could be mounted on the left side.RTIII said:..I was under the impression brake cut-out switches are unnecessary and not provided?!
Can someone explain, please, what are these "left-hand switches" all about? I thought the VLCD5 that comes with the kit had all the functions? You need both?...
RTIII said:The current images posted on the official Tongsheng web site show the TSDZ2 with brake handles and "left hand operation switches", and these confuse me.
Here's a link to what I'm talking about:
http://www.tsbicycle.net/products_detail/productId=136.html
Also, I'm about to order one of these and the vendor has it pictured with the XH18 controller / display and NOT the VLCD5. But, given my handle bars being the traditional 10-speed (curl down and the outer ends are pointed rearward), I figured that would be bad because it's 90 degrees opposed to the rider. Yes, I could change handle-bars, but... ... So, I asked and the vendor wants - if I understand them correctly - $50 more for supplying the kit with the VLCD5 instead. I think that's crazy! But another thought came to me; while it's dry here most of the time, what about weather-proofing? <b>Any comments, please, on the weatherproofing of the electronics?</b> ... the XH18, VLCD5, "left hand operation switches"? ... THANKS IN ADVANCE! ... If none of this is weather proof, I'll have to come up with my own solution, but if some is and not others, now would be a good time to know!
Hickory said:HI RTIII- I got the same motor from auto-ebike about 1 month ago. Regarding the chainwheel- I just have the one that came attached to motor, and it seems just fine. Give it a try before you add a second one. I didn't go for the throttle.
Right! And I promise to only use the throttle like that also...RTIII said:....So, $290 + $185 = $475 USD, + shipping. They also have an online-purchase discount of $15, and I'm expecting (from reading other people's reported experience buying from this site) that the battery will be $70 to ship and kit $60, making a total cost of $590
... My use for the throttle would be emergency circumstance (if I get a minor injury or am too tired to pedal, etc). Any comments on that? I can run either / or both at the same time (PAS and throttle), right?
Norton said:Right! And I promise to only use the throttle like that also...![]()
You found some great prices to get the system!
I looked at sites like this and ebay. Are you concerned about statements like this?: International items may be subject to customs processing and additional charges.
I am paying so much more... I'm getting a 17.5Ah pack and the confidence of buying through amazon, but still...
Keep us informed about how this works for you and I'll do the same!
jb,jbalat said:... Using the standard 42t on front fitted with derailleur to stop chain falling off and 12-36t 9 speed rear but even on steep climbs haven't needed to use the 36t yet. ....
Can't really recommend it for commuting, I find I'm always on level 4 and just working hard near the end of the battery as voltage drops off,.....
... so far so good, can't recommend this motor enough for off-road...
