Hey guys,
I am so excited to finally make a build with one of these... I have been holding off for a loooong time with this one, but I am kind of sick of the BBS unit... I want something fresh, something new (to me)... SOMETHING WITH A TORQUE SENSOR!
I have been following this thread for a while, good info, thanks. Also, for around a year, I have been following this unit, and doing research, etc... Not that easy... I even talked to MXUS (yes, V3 Turbo mxus) who claim to have done research with TS on this unit, and sell it with their own logo sticker in the center circle...
It's clear, the display goes to 60v MAX, but even the 48v 500w models motor's top out at 54v MAX, so no 14s... (well, no charging and using over 54v, anyway, the rest is up to you).
I cannot get a real answer on the controller inside these things, and that is kind of annoying... I have been hoping to slightly beef up the controller, and add a better gear... I cannot find one for sale (although someone said there is one available?) and I cannot even get an answer that is decipherable as to the controller differences, and I am pretty good with international communication, and even have assistance. The answer is twofold - a) they don't know;; b) those who know, don't want you to know. I think a lot of us know that.
Anyway, I have a couple units on the way, and I have been wanting to test these out for a while even since someone I knew had one, but it was way back when they only had 36v350w... no thank you... I was BBS on 52v, solid rims, and solid tires with no flats around Nashville =) but let me tell you, to ride on those no flats (at that time), I could not use less power or I would be breaking even hahaha. It was worth it after getting a flat @ 30mph. I swear, I am a ninja, and landed backwards on my feet in a skid just palmed my hand a little at the end, BUT - tweaked my back in midair pretty good situating myself to do so. so point is, I need more power to muscle through the soft no flats I was rollin on back then, and the 36v350w was NOT gonna cut it...
Nowadays, I know there is a time and place for everything, I can have a power ride set aside, sometimes local legislation, or just city safety means 20mph limit, 30mph max (even excessive in busy downtown area for sure). And... that's fiiiiiine. Just fiiiiiiiiiiiiine :| haha
Anyway, I will be using those RIMS, and some 2.00 solid tires, on the build BELOW:
I picked up one local for a real good deal, and the rear shock is upgraded manitou... front is a 888 bomber... only spring, but seems good quality... I LOVE the high BB clearance...... so I am throwing on the TSDZ2 (the 3 is special frame only model) with an XH18, wired up to throttle and brakes (using hydraulic E-brake for this kit), and will test a few things.
The Plan:
1) Find or fabricate a better motor gear than the blue plastic available (any direction to point me? I thought someone mentioned one being available).
2) I will see what this thing can handle POWER WISE, and post the results...
2a) see what it takes for the blue gear to butter up (if first to failure)
2b) see what it takes for the motor to get dangerously hot/burn up - even wiring it to an external controller for testing purposes... (I am looking to make these things a little bit better).
3) I have the 104 and 130 attachments, and got the chain rings from 34 to 52 (don't ask why)... but honestly I only need the 104, and 130, because like 'ol buddy with the slick website - I am going to toy around with putting a double chain ring on this thing... I mean, I want to be able to pedal to 45MPH on flat ground... which a double chain ring and the assist here... I bet it will burn my thighs but I'll post a 45MPH flat... that is my goal with this.... hahah. I don't know... 45mph was tough with a BBS02... The double chain ring might not help me if I cant push it... (even with help from lil Thomas the TSDZ tank engine
4) I really really want to use my solid rims (love the look) but I might go for an IGH instead ( I just picked up some nuvinci autoshifter, I have to resist using those heavy monsters with this.)
5) I will get down to the bottom of the exact controller situation with these things, and see about the wiring... and post some closeup pics etc for anyone.
I appreciate everyone adding to this thread... if anyone has any advice for me, or any requests for when I test/beat the **** out of these motors, let me know!
UPDATE:
UGH, I am torn... the downhill bike (got a great deal) iiiiis a little overbuilt for this type of thing, and I am going to have to do some fabricating... although I really want to... may take forever... ON THE OTHER HAND - I can wait maybe 30 days... and get this:
https://www.aliexpress.com/item/Kaloss-Full-suspension-frame-electric-bike-alloy-frame-E-bike-26-17-inch-Free-shipping-mountain/32797177342.html
Not bad... another ali supplier... about $500 for the frame and some 'flashy' wheels... although really, I think this frame with an IGH will be a real sweet compact around town setup. It can hold 13s*4p, so I can have 48v14ah (sanyo).
Ok, I am going to make:
1) TSDZ2 on the DOWNHILL NORCO FRAME with SOLID RIMS, supped up with double chain ring, replacement gear, and TEST THE LIMITS of the gears (before I replace), the motor (after I replace gears), etc... hooking it up to an external controller if heat kills the controller before the motor... which I actually won't let happen if I can help it, but... y'know.
Once I break the motor on this build, I will use the downhill frame with my own experimental mid drive cyclone style setup I am wanting to try, and see if I can integrate a BB torque sensor in with it... I think that would really be nice... I am going to hit this baby with a domino throttle, and a left/rear brake because once I make this baby my own, not just a testing machine, she will be a wheelie monster!!!! =)
2) TSDZ2 build on the FOLDING ELECTRIC FRAME, WITH IGH, for an 'elegant folding' around town thing, that I will probably keep.
