When did you buy your seven TSDZ2 kits? They don't seem to be available anywhere currently and has been that way for the last 6 months or more. It's not even on Tongsheng's website
Mid Motor_Products_Suzhou Tongsheng Electric Appliances Co., Ltd. Motor Meter Controller , only the TSDZ2B, which is suppose to fix all the issues with the TSDZ2. Apparently they have not succeeded at least per EBC.
What happened to your TSDZ2's that failed? What kind of riding and what environment were they used in? Do you have brake cutoff sensors? I rode w/o brake sensors for 300 miles before installing them. W/o brake sensors, I've experienced instances while coming to a stop, with brakes engaged, my right foot's weight was on drive side pedal at 2 o'clock, approaching to 6 o'clock when I take my foot off pedal to dismount. Between 2 and 6 o'clock, the motor was still being powered, fighting the brakes. That can't be good for the plastic gears and motor. Since I installed the brake cut sensors, I do not experience that anymore.
