Thud
Cool,
After reading that it becomes clear.(duh!) Thanks gwhy.
I really am an eletronic duffass sometimes.
johnrobholmes said:My question is whether the 18fet (or any of the zei chang) controllers will actually allow high current flows. The boards are relatively puny and not designed to minimize inductance or maximize switching speed. Even the power wires enter and exit with an extra 8" of wire inside the controller. Sure, the fets may be able to take a lot of power, but can the rest of the controller?
Certainly, I do think they are great controllers and do a great job (especially for the price). I just have more questions than answers about them :lol:
Hi Gwhy,gwhy! said:I have no doubt that these controllers can handle much much more than even methods 100A 100v controller. If my little 6fet can handle 100A ( im soon going to be testing hopefully not to destruction one of my 6fets upto 120-140A for R&D purposes with the big motor that I have) im sure that a 18fet can handle much more but I do think it may require different fets to be used.
deVries said:Hi Gwhy,
This is good news that you can get a 6fet to handle 100A. Because 18 FET 84-132V Infineon Programmable Brushless Controllers with high voltage IRFB4115 MOSFETs are BIG and cost $259ea. from L.
Is it possible and reasonable to mod a 6fet to do 48v nominal and 75A continuous for 2-4 minutes without overheating? Also, need to get the motor up to 9,000rpm. 14 magnet -not sure if this is the same as how many poles the motor has???![]()
How much approximately are the supplies to mod the 6fet and to add the hall sensors to an outrunner similar to yours? Just trying to get a total cost picture before diving in.![]()
Cheers,
Thanks!
liveforphysics said:Remember my friend, the FETs only feel the phase current.
For example, a 50v setup with a 50amp limit may be peaking 150amps (an example).
Cranking up the voltage to 100v, with the same 50amp battery limit would place the phase peaks in the 300amp+ range.
Or, if you have a pair of controllers, both drawing the same 50amp from the battery, but one is terminated in wye and the other in delta, the FETs in the delta motor will be having 1.7x higher phase currents.
Or, if they are both set to pull 50amps from the battery, and one is powering an x5304 and one is powering an x5302, the x5302 setup will have twice the phase currents (and hence twice the fet loading).
What I'm getting at, is a controller may work fantastic for one person at 50v and 100amps or even 150amps, and get utterly exploded by somebody using the same controller at 130v, and only drawing 50amps or less.
Keep in mind, these 4115 controllers for 150v are only capable of about half the phase current of a controller with the same number of FETs made from 4110's. And yet the higher voltage is going to mean it's getting a lot more phase current multiplication... If you try to power a low resistance motor with it, you're going to be looking phase currents at >4-5x battery currents, and the fets ONLY feel phase currents, so it doesn't matter if your amp meter is only showing 50amps, your FETs may be under 250amp stress.
If you're going to run the very high voltage setups, you MUST choose wisely to match the motor to the controller voltage, or there will be a lot of people with sad faces wishing the magic smoke was back inside there controllers.![]()
Does 14 mags = 14 poles? One has to divide the rated controller's electrical speed by the number of poles to determine whether the controller can do the rpm one needs. Will your controller do 9,000rpm with a 14 pole motor?gwhy! said:My 6 fet is limited to 70A now (but have run it with 100A limit ), running on 44-50v and copes with this very well ( dont get even warm), but I have not pulled this current for more than 20secs. If you want it for 2-4 mins then I would reconsider re-gearing your setup. The motor Im using also has 14 magents. The total cost for the controller mod was around £30, this was for the fets ( not 4110's ) and for a different box and heat sink, the cost of the halls were £10 plus a bit of jiggery pokery to mount them.
Since the phase currents are what the motor gets, would it be better to run the lower resistance Outrunner at higher voltage but lower amps for stop to start-up and acceleration purposes (to 30mph) AND maybe keep the heat build-up lower in the motor or elsewhere? (vs lower voltage & higher amps) This is using a modded XieChang controller with hall sensors on the Outrunner, or is higher voltage only going to help out at the top end after start-up and acceleration PAST 25mph?liveforphysics said:Keep in mind, these 4115 controllers for 150v are only capable of about half the phase current of a controller with the same number of FETs made from 4110's. And yet the higher voltage is going to mean it's getting a lot more phase current multiplication... If you try to power a low resistance motor with it, you're going to be looking phase currents at >4-5x battery currents, and the fets ONLY feel phase currents, so it doesn't matter if your amp meter is only showing 50amps, your FETs may be under 250amp stress.
deVries said:Since the phase currents are what the motor gets, would it be better to run the lower resistance Outrunner at higher voltage but lower amps for stop to start-up and acceleration purposes (to 30mph) AND maybe keep the heat build-up lower in the motor or elsewhere? (vs lower voltage & higher amps)
deVries said:Does 14 mags = 14 poles? One has to divide the rated controller's electrical speed by the number of poles to determine whether the controller can do the rpm one needs. Will your controller do 9,000rpm with a 14 pole motor?
Yes, I agree, the 2-4 min at 75A is overkill but maybe up to 45-60 seconds instead but typically only 15-30 seconds on demand? (Bursts of 85A for less than 30 seconds are what the motors are rated for, but that is in an rc-airplane air-cooled application.)
So, do I need a high-rpm (high electrical speed) 6fet controller that can do 9,000rpm? How do I "spec" that? I have read some controllers have issues at these higher rpm requirements.
Thanks Luke for taking the time to connect the dots for me to begin understanding, rather than what was becoming a conundrum of misunderstanding.liveforphysics said:This is why it's so critical to match the motor to the voltage. With these RC motors with super low winding resistance... it takes some serious controller current handling abilities if you want to run them past 100v, or hell, even past 75v.
Another quick example, you could take 2 different 3220 astro motors, one of them a 6 turn, one of them a 2 turn, and run them both off the same 50v pack limited to say 100amps. The controller on the 6-turn might be happy and run nice and cool forever pulling 100 battery amps feeding the 6-turn, while the same controller with the same 50v and same 100amps going into it could be shooting out plasma and magic-smoke, even though it's battery current and voltage going into it is identical, it's phase currents (and hence the load the FETs see) was triple that of the other controller running the 6-turn.
What voltage do you need to reach 27mph?gwhy! said:I have run my motor at 60v with my controller which works out @ 10200 rpm yes it works but I haven't run this for any great length of time with a 70A limit so cant say for sure if it will be ok in the long term. my bike for normal road use only sees 70A for around 1-2 sec when accelerating hard and this pushes my upto 25-27mph. So I think to reach 30mph should not be to much more ( my bike weighs around 20kg ).
deVries said:What voltage do you need to reach 27mph?
Someone told me to get a good estimate is to pad your voltage about 20% over the no load rpm to get a good voltage estimate for mph on the flats under load. Does this make sense or do I need to use a different calculation/percentage?
Thanks,
Cheers!
swbluto said:Battery current does relate to phase current because, as you say, phase current relates to power and lower battery current with the same voltage in consideration IS lower power.
If you don't believe me, go to http://ebikes.ca/simulator and use the "custom option". Choose whatever motor you like, and plug in two different battery current limits. Look at the motor torque, and understand that's just a constant multiple of the phase current. You'll notice that a lower battery current results in lower torque, i.e., lower phase current. Why? Lower power, as has been said. So, yes, they are related.
Higher voltage and a lower battery current, though, isn't necessarily better for the controller. Lower voltages will result in lower controller heat.
recumpence said:Funny thing, though, if these things are setup right, they run and run and run. My PK Ripper still has the same two HV110s I built it with and it is running fine without any problems after 2,000 miles and that thing is beat to death always!
Matt
Thud said:I am ready to take all this E-bike BS & throw it into lake michigan. I have exausted my e-bike budget trying to get a little performance out of them. (remember I am an "A" class vet motocrosser)
Thud said:I am tempted to pick up another HV160 & get some damm riding in. I am tired of soldering blown fet's
Thud said:I was so angry I orderd a rebuild kit from race tech for the shock on my 89 CR125 training bike....& I picked up a morini S5GS engine last weekend....I will be at the death race next spring...I just question whether it will be on an E-bike right now. I am realy heart broken.
