small update
Tabless design cylindrical cells tests
added low power cycle life graph at 90% (4.15-3.00V) for HP cells.
- 40PL doesn't seem to have a life cycle problem at low power.
- 40P so far shows standard cycle lifetime at 5C discharge
I'm thinking there's no reason why a 40PL should have significantly worse cycle life than a 40P. I assume the active material and electrolyte is identical. Plus
@CamLight has a good result in his tests. I was wondering if I could have damaged the internal tabless interconnects on the anode using Micro-TIG welding (1C test is running in BF-2A holder only) Although very unlikely, I'll still try to run the 5C test also in the BF-2A holder. Temperature-wise, it should still come out fine to about 60°C (with Cu strips the 5C discharge end temperature is around 50°C for 40PL and 60°C for 40P)
Also BAK 45D arrived, so on monday I will start with testing. BTCAP 40P (together with Lishen 58SK) are ordered but delivery time will be long like 40 days.
And finally the JP40 with two other interesting samples (not yet released) from 18650-21700 store are also on the way to me.
