void calc_foc_angle (void)
uint16_t ui16_temp;
uint32_t ui32_temp;
uint16_t ui16_e_phase_voltage;
uint32_t ui32_i_phase_current_x2;
uint32_t ui32_l_x1048576;
uint32_t ui32_w_angular_velocity_x16;
uint16_t ui16_iwl_128;
// FOC implementation by calculating the angle between phase current and rotor magnetic flux (BEMF)
// 1. phase voltage is calculate
// 2. I*w*L is calculated, where I is the phase current. L was a measured value for 48V motor.
// 3. inverse sin is calculated of (I*w*L) / phase voltage, were we obtain the angle
// 4. previous calculated angle is applied to phase voltage vector angle and so the
// angle between phase current and rotor magnetic flux (BEMF) is kept at 0 (max torque per amp)
// calc E phase voltage
ui16_temp = ui16_adc_battery_voltage_filtered_10b * ADC10BITS_BATTERY_VOLTAGE_PER_ADC_STEP_X512;
ui16_temp = (ui16_temp >> 8) * ui8_duty_cycle;
ui16_e_phase_voltage = ui16_temp >> 9;
// calc I phase current
if (ui8_duty_cycle > 10)
ui16_temp = ((uint16_t) ui8_adc_battery_current_filtered_10b) * ADC_BATTERY_CURRENT_PER_ADC_STEP_X512;
ui32_i_phase_current_x2 = ui16_temp / ui8_duty_cycle;
else
ui32_i_phase_current_x2 = 0;
// calc W angular velocity: erps * 6.3
ui32_w_angular_velocity_x16 = ui16_motor_speed_erps * 101;
// 36V motor: L = 76uH
// 48V motor: L = 135uH
// ui32_l_x1048576 = 142; // 1048576 = 2^20 | 48V
// ui32_l_x1048576 = 80; // 1048576 = 2^20 | 36V
// ui32_l_x1048576 = 142 <--- THIS VALUE WAS verified experimentaly on 2018.07 to be near the best value for a 48V motor,
// test done with a fixed mechanical load, duty_cycle = 200 and 100 and measured battery current was 16 and 6 (10 and 4 amps)
// calc IwL
ui32_temp = ui32_i_phase_current_x2 * ui32_l_x1048576;
ui32_temp *= ui32_w_angular_velocity_x16;
ui16_iwl_128 = ui32_temp >> 18;
// calc FOC angle
ui8_foc_angle = asin_table (ui16_iwl_128 / ui16_e_phase_voltage);
// low pass filter FOC angle
ui16_foc_angle_accumulated -= ui16_foc_angle_accumulated >> 4;
ui16_foc_angle_accumulated += ui8_foc_angle;
ui8_foc_angle = ui16_foc_angle_accumulated >> 4;
