EndlessCadence said:
Hi casainho, I've quickly flashed both your 0.4 hex files. Configuration using LCD3 was easy but motor somehow isn't running great with this software. Display shows a constantly varying speed and there is no way I can get it right with repositioning the speed sensor. The speed sensor hasn't been changed during the update. Do you have any idea what could be wrong? The motor also feels a bit rough now but that can be caused by the varying speed sensor. I've also noticed that the PAS max cadence was 0 by default (on the display).
I just tested again and found that issue with the wheel speed. And found that I did a small mistake. As for motor, my seems to run just fine!! Can you test to flash again the firmware and make sure you configured correctly the parameter for 36/48V motor?? (that was the only thing I changed about the motor).
About the PAS max cadence, I just verified (after erase the EEPROM) and I got as default value 110 as expected.
Maybe you need to erase your EEPROM before flashing....
I just uploaded the V0.5 with the corrections for wheel speed.
