andrewgateway
- Joined
- Sep 5, 2019
- Messages
- 17
casainho said:Can you put on the numeric fields the human power and share here your average value as also a min value?andrewgateway said:dameri said:casainho said:So, I think you need to focus on the values around the knee of the graph, maybe trying to measure 5 values near around, because that zone will have a big impact on the values calculated. Also I think is important for you try to imagine a soft round curve passing on/near all the points and so you can estimate some of that values.
As we can see, your torque sensor is like mine, good sensitivity only from 0 up to 20 kgs.
Ok, thanks. I do changes at weekend.
Hi did you try any new settings, I am also having very little assistance after calibration.
And then, put on numeric fields the motor power and compare motor power VS human power and see if it follows the assist level rate / factor multiplier??
I installed the latest firmware on the motor and display, all is working well.
The up and down buttons work the wrong way round?
Sent from my iPad using Tapatalk Pro
