I want to flash the new version 0.13.1, but still have my two questions :?
1. I flashed the motor with 3 cables connected : +5V, GND, SWIM and battery disconnected following these instructions : https://github.com/hurzhurz/tsdz2/blob/master/programming.md
I did not connect the RST cable marked as otionnal, it has worked, is it OK ? What is the use of the RST plug in the middle ?
Also i di only flash the program TAB not the DATA or Option TAB, do i need to flash all tabs ? It seems to work like this.
2. If i wan't to upgrade to 0.13.1 what is the exact procedure ? Do i need to reset something ? Or simply flash program tab over current firmware for the LCD3 and motor ?
