jbalat
Ok so i stopped and started many times on my way in to work today. Due to display historesis I am unable to give you EXACT data but this was my perception.casainho said:Help to debug lag issue
See about this issue here: https://github.com/OpenSource-EBike-firmware/TSDZ2-Smart-EBike/issues/9
For the ones that are interested in helping solve this issue, please help by looking at the following values on LCD3:
9: Advanced technical data
submenu number configuration name description
3 Pedal torque sensor
4 Pedal cadence
5 Pedal human power
6 PWM duty cycle
The idea is to see how that values changes when the issue happen, like stop pedaling and then pedal again and look at that values. How do they change when the issue happen?
Even after you stop pedalling the cadence drop slowly to zero, not immediately, if you peddle before it gets too low then there is no lag, if you wait too long or let it get to zero then lag exists.
Taking off from zero has less lag than when you start pedalling again while rolling
All the stats like torque sensor, cadence, human power, pwm and even ERPS motor speed all appear to work as they should however it appears you dont get any boost until ERPS is about 200.
When taking off from rest the ERPS 200 is achieved quicker ?
Perhaps when energising the motor we just add 200 offset ?
This brings me to my next idea.
Can we use a minimum ERPS to prevent backlash in the gears and reduce noise. The issue is to try and calculate the minimum ERPS based on your cadence so as to make sure gears are always tight but not too much to overheat the motor ore make the bike move. Of course when the wheel speed is zero then this should be turned off
