casainho
10 GW
- Joined
- Feb 14, 2011
- Messages
- 6,058
Seems you are having issues with your firmware... it does not work for me as you say, it just give more power when I increase the assist level (using the default values).jbalat said:I think we need to go back to the old way which sets the assist level as a multiplier (i believe this is how my Bosch works) that way you can use the quick power setting to get the best combination of assist and power while you ride depending on conditions and how tired you are
Power boost is needed because before we also had power boost but in a way it was not configured that a user complained that could not reduce the power boost (because it was to strong for him), then I implemented power boost to be configured in power and time duration. Without power boost, you have only human power that will always be near zero when you start pedaling/low cadence, this is not good as we also want assist at startup and lower cadences.jbalat said:Also the power boost stuff causes problems. As I am coasting down hill and back off power then try to go uphill on the other side i get no power for at least 3 turns. I would also like to leave this out as it is not necessary and causes problems.
But yes, power boost as that issue you mention, the only way is to debug/try understand in what combinations it fails to work.
