twiersum said:PhotoPictureResizer_190716_184252676_crop_2132x2192-852x876.jpg
I Lost 8oz on my main drive gear....next I'm going for 4 more oz with a smaller needle clutch bearing.
This thing is built like a tank with a Prius motor!
shaddi said:Hm, i do not understand the intention of the "street-mode" after the changes >18.0.
If i get off the public roads, i would like to use a button-combination (that should not be to "easy" and get
activated "by accident") to enable an offroad-mode or disable the new "street-mode".
Why is this changed in the new version? For me, it just looks like an inversed offroad-mode. Why would somebody
want a mode, that obviously get attraction by the blinking assist-symbol for "street-mode"?
shaddi said:For me, most of the time i'm on the public streets where (at least in germany)
you are not allowed to get assistance over 25 km/h and have to limit the power to 250 watts.
Of course, cruise-mode is also not allowed...
jimmyfergus said:buba said:Quick update for anyone interested.
I am very satisfied with how everything is working but have a couple of things to do. Am now focusing on the cadence sensor.
Sweet! I'm just about to go on vacation, and very enthusiastic about trying all the new stuff some time after I get back in August.
Thank you!
andrea_104kg said:The compliments are always too few for the work you are doing which is wonderful.
I quickly read the new wiki of the future release 20.0 and I didn't understand the three ways:
- cadence
-torque
- emtb
That is, for a comparison, in the current version 19.0 which system is adopted?
I am puzzled by the separation of modes, is it not a mixture now?
Will there not be a similar mode to the current one?
You may not have understood correctly because of the language, excuse me ...![]()
thineight said:fi7ippo said:twiersum said:PhotoPictureResizer_190716_184252676_crop_2132x2192-852x876.jpg
Wow, a lot of work!! Very good job! I think that if you not use the cruise function as me and many others, you can safely remove the clutch bearing and use an thickness of aluminum keyed! This paired with along with your lightening solution would save a lot of weight :thumb:
Not sure you can get rid of the clutch bearing.. when you stop pedaling the motor still assists you for a little while therefore without the bearing the pedals, and so your leg, receive a unwanted "kick".. am I right?
andrea_104kg said:Thank' for replay buba! I have some difficulties with english![]()
It will be possible, on lcd3, to have a mix of mode, as emtb on level one and the other in power mode?
buba said:Power Assist = ...
Torque Assist = ...
PAS/Cadence Assist = ...
eMTB = ...
U_battery * I_battery = torque@crank * cadence * 2PI * assistfactor
I_motor = torque@crank * assistfactor
I_battery = I_max * assistfactor
I_? = torque@crank * assistfactor * (1+wheelspeed/wheelspeed_max) *???
buba said:Most electric bikes can only sense crank rotation.
buba said:Great progress!
I have increased the resolution of the cadence sensor and it feels and works better than expected! We are effectively doubling the resolution and it is almost as if we have 40 magnets instead of 20. It gives power almost instantly and it powers off very quickly! And this is without any optimizations or scaling of resolution depending on wheel speed so it can only get better if we want to!
However, whenever the hardware is lacking we instead need to create better and more complex software. So this new cadence sensing code is more complex but I will simplify it as much as possible. Will also explain what I have done and maybe even make a video. Execution time, performance and everything else is the same if not better.
I am so sorry if the community feels the development is taking too long. I am truly doing my best and can only ask for more time and patience. In return we will have a foundation that is forever rock solid and can instead focus on displays and riding modes.
buba said:I am so sorry if the community feels the development is taking too long.
stancecoke said:buba said:Power Assist = ...
Torque Assist = ...
eMTB = ...
Hi buba, would you be so kind to post the formulas behind the modes? I don't know, where to find your sourcecode, is it in some of the existing forks?!
If you call it eMTB- (e-mountain-bike) mode I would assume, that the power should increase with decreasing speed at constant system power (means that you are starting to climb a hill)
If you increase power with speed just to compensate the higher air resistance it has nothing to do with a mountain :wink:
regards
stancecoke
stancecoke said:buba said:Most electric bikes can only sense crank rotation.
I think this must be "Most cheap electric bikes can only sense crank rotation." Most more expensive bikes (with Yamaha, BionX, Panasonic, Bosch... motor) are using power mode or even more complex modes....
perryscope said:Sounds great very much looking forward to testing this!. No need to apologize Buba you are doing a fantastic job!
jimmyfergus said:Personally, not at all!
I'm impressed at how much you've done hard on the heels of 0.19.0. Way more rapid than I'd expect. I'm only itching to try it because it sounds so good.
buba said:eMTB is based on this:
https://www.bosch-ebike.com/en/news/no-trigger-the-new-emtb-mode/
stancecoke said:buba said:eMTB is based on this:
Hm, the information in your link is just markteting-bla-bla :wink:
stancecoke said:I'll just wait until you commit your latest changes at github and then I'll take a look at the formulas in your code. Perhaps you can give a hint in which file and line number I can find them![]()
regards
stancecoke
buba said:The logic was inverted from the beginning and some users reported that it was complicated. It should be easier to understand Street Mode and how it operates.
buba said:But you and others have given good feedback regarding the blinking. It should be able to blink when Street Mode is not enabled but the function is activated. So this will be sorted out in the 0.20.0!
hm, for me this is too easy to guess. I dont want to risk that some officers try pushing around the buttons and disable the street-mode by "accident". But please, get your focus on the controller firmware; cant wait to test your work!buba said:Street Mode is enabled by holding the ONOFF and DOWN buttons for a short period of time. This is so users can somewhat easily and discretely switch between different modes. Do you feel this is bad?
Thanks! Have done it already on my fork, but cant get that damn sdcc to compile it. So waiting for your versionbuba said:Will take a look at Cruise in Street Mode!
shaddi said:hm, for me this is too easy to guess. I dont want to risk that some officers try pushing around the buttons and disable the street-mode by "accident". But please, get your focus on the controller firmware; cant wait to test your work!buba said:Street Mode is enabled by holding the ONOFF and DOWN buttons for a short period of time. This is so users can somewhat easily and discretely switch between different modes. Do you feel this is bad?
Im trying to find a better solution by myself and send a pull-request for review..
Quite hard to find a good balance between "complicated" and "ergonomic"![]()
TSDZ2 was my first mid drive motor and I like it because I can install in any regular bicycle. I would not like to start a project for something very specific, I mean a motor for a specific frame -- like I was able to install TSDZ2 on a 24 wheel for my son and I think there not much ebikes with that specific frames, for kids.El_Topo said:Very interesting development, I am following the development of this and from what I can tell you guys are doing a great job!![]()
I did a quick search but didn't find anything so please excuse if this has been asked before:
Do you plan to support other common motors in the future? It would be great to see something like this for Bafang's range of mid drive motors like G510 and G521.
Also, did you consider implementing shift detection?
