jeff.page.rides said:OK so at what cadence or RPM does the 36 Volt torque pass the 48V torque?
If possible I would love to see the 2 torque curves on the same graph showing at what RPM the 36V torque overcomes or passes the 48V torque and at what percentage they are more or less than each other.
I think knowing exactly what this is will help everyone decide whether they want a 48 Volt or 36 Volt motor?
Based on Buba's calculated torque constant, and using the rated no load speed (4000RPM) and overvolting the 36V motor by 1.33x (48V) I came up with this. The hatched area is higher torque from the 36V motor above 52 pedal RPM's
EDITED -- OK I fixed the drawing, and moved the line for the 36V motor up, making the crossover point lower
