Martin555
10 µW
- Joined
- Apr 25, 2020
- Messages
- 5
nassal said:Please help. just flash the v0.7.0 to 860 display but doesn’t communicate with TSDZ2, it shows errors brakes. Flash the TSDZ2 with v0.56.0. Breaks connect to green and black wire. Any idea what is wrong.
This error message appeared in past, when firmware version 0.58 and above was running on the motor, but the display had an older version on it (due to the changed communication frequency). Have you tried to downgrade? Was the firmware flashing on the motor successfull (message "program code successfully verified")? And is it working when you flash the latest Alpha version on both the motor and display?
