Hi guys, I've been messing around for days to flash and connect the 860C display to the TSDZ2 but I just can't.
Meanwhile, an easy question: is the 860C display (with the appropriate wire changes) compatible with the TSDZ2? That is with the original engine firmware, can the display show basic parameters like the VLCD6?
And now the hardest part: installed and configured drivers and software for the bootloader as indicated in github website, the display turns on so is powered correctly, but any attempt to program it with "Apt Burn Tools" fails.
I connected the two wires for the power supply and the two TX and RX wires, leaving out the orange wire of the display whose function I don't know.
Apt software shows "Waiting..." but nothing
List of all attempts made:
- correctly identified the COM port
- swap the RX and TX cables in both ways
- tested on laptop and desktop PC both with Windows 10
- all display keys work correctly
- programming performed with and without Administrator privileges
- numerous attempts to restart the display before and during programming
- tests performed with different supply voltages (between 27 and 38 volts)
- pressing the power button on the display both with the screen on and off
- duration of pressing the button from a simple click to a few seconds
- tests carried out with three different USB-UART bootloader
Could it be a non-reprogrammable version of the display?
