Hey!
edit: solved, common ground was missing.
I am trying to flash my 860C with the OSF firmware, however I can't get the flash to start in the APT Burn tools. I downloaded it from here:
APT Burn tools v1.4 - bikel.pl which is the only place I could find it. On the back it says V58, while on with the OEM firmware it says hardware version P1.3 so I used the " 860C_V13-v20.1C.5-1-bootloader.bin" from the github. I am using my battery for the power source and have wired in a FT232 USB TTL converter, and I have seen someone mention they used this? as well as the flashing guide saying any USB TTL should work.
When I wire TX to RX and RX to TX:
I open the port, select the firmware and start the update both TX and RX values go up, if I press or hold the power button the RX stops briefly and then starts back up again. If I hold the power button it also boots the OEM firmware and as stated before the RX continues.
Wiring RX to RX and TX to TX
Opening the port, selecting firmware and starting the update first the TX value only goes up, but then the RX also starts to go up? pressing or holding the power button makes the pause of "rx not going up" to last longer, however after a while it starts going up again. Holding the power button like this does not turn the display on at all.
I have only wired the P+, GND, RX and TX, not the VIN. I also never connected the GND of the battery to the GND of the TTL converter, maybe this is my problem?
Edit: The common ground was my problem, managed to solve it, sorry for not trying that first before posting tho, only figured it out while writing.
I can't find anything about anyone having the exact same issue as me, any help would be appreciated! Once again; thanks for all the work you have put into this awesome project!
Thanks,
Philip
