My latest versions of OSF cannot work without a speed sensor connected and working.Hello, is it possible to use this latest version (v20.1C.2-update-2) without a speed sensor or is this required for function? I was using an older version of OSF and tried this latest version in hybrid mode and it was AMAZING, except for the E0.8 error shutting off power constantly.
This bike is used off-road and I have no need to know my speed, on rough terrain I would be very worried about the speed sensor becoming dislodged/misaligned from the rough surface or during jumps.
I thought a previous version had a setting to allow assist even with the E0.8 error, but I don't see it in the latest version. Thank you.
Error E08 appears and assistance is removed.
It is possible to ignore the error and continue with the assistance by enabling "Assist with error" but only on the display, not on the configurator.
"Set parameter on startup" must be enabled, see manual.
Then at level 4-TURBO, press the lights button 2+2+2 times until E04 flashes. It will work until turned off.
If you want the setting to be retained it is necessary to store it in the eeprom.
So before turning off, at the 0-OFF level press the light button 2 + 2 + 2 times until E04 flashes.
