Tabless design cylindrical cells tests
I just wanna say yall are doing some good research. Good, hard numbers. Exploring these round can cells well. Good vid, Reba, shows the capability of this cell in real world well. That IR is unbeleivible.. and for a small cell, well yall know what happens. Sucks cause they might be really expensive for a long time.. at least these will push the Molicell fans into affording enough for a good pack. Without spending 3K.
lol. Got blessed, so much trouble for a pack. My K- Weld sits, weeping, thinkkn bout the future. these cells are decent. Finally good power out of a round cell. I cant believe that IR.
On another note, I was told to take IR on charge only, and when you hook multimeters with different AC signals comming out of the leads.... it fiddles witht he HRM 10 readings... my scope told me. maybe that is why it shows so low.. I would like to see the cell tested with that machine alone. Both cells show different from manuf published ACIR numbers? the moli and the jp40...? I did check the accuracy of mine, as long as the probes are connected and its not hooked up to a multimeter in circuit its accurate... Do you notice the difference if you apply a charge, vs discharge, while reading with that meter/ this is my test today.
The multimeter is absolutely outputting a AC signal sine wave voltage and the HRM 10 manual says to absolutely NOT apply ANY AC voltage to the leads. Live dangerously lol its only 40$ eh? Be careful, I noticed som e flycback spikes when i was checking mine out. ... between the meter and the HRm... with my 10 megahm input resistance scope. Weird stuff happening. be careful. IDK if it messes anything up but .. IDK how a round cell could show that low. Good god. Dont put that shit loose in your pocket with some coins.
Lol Fukes suck anymore. Taiwan. China. ...built.
That is absolutly craxy. 100A out of that cell. gebus. i cannot get over it. ol.
Also wanna say I'll still destroy ya in the power department, amp hour for amp hour, using these thingies all day. Cheaper and longer lasting. Finally a cell that can compete. Yet yeah 100A gets ya really hot.. and if that was spread over .. say.. a 5p pack, group, that would be good and it wouldnt get hot. Finally a powerful ebike cell that I would be willing to bujild with .. and IF I can get that power from a smaller pack, of say 100x of these cells.. that would be awesome... a 5p20s, 100 cell pack with a group IR of 1/5th an mOh. Lol goddam. No sag ever again.
My cells dont get temperature until 4C ( 100A) and not 25* till 6C and well over 250A contin capable ea. I love comparing the best round cells to the Ev cells of the top of the line market nowadays.
lol. Im not hoping. I'm knowing. Ok I'll go back to lurking now.
The standard is ACIR at 30% SoC and at rest in my experience. Not sure if JP40 specs have been published anywhere, but most cells I've tested (P45B, EVE 40PL relevantly) are pretty much dead-on (slightly better than nominal spec).
Kumyang has some tabless 46mm cells (46/80*, 46/95, 46/110* and 46/120*) in the making :)
(* are under development as "Energy" variants; here's a shameless crosspost with more info.)
Those copper ends look beautiful, but do you have a photo of the aluminium end?
Wow these look like pure garbage, how did they manage that lol?
And while 4860 looks to have a good cycle life characteristics, 4695 looks much better based on numbers alone
The very annoying possibility that they used a high concentration of methyl acetate in their electrolyte to further boost power density without considerations for cycle life with graphite anodes at high voltages (>4.10V).
There are other possibilities like improper cathode:anode capacity ratios, poor electrode adhesion, etc, but the electrolyte mix being quite... unoptimal is the most likely reason for such poor performance; you can tell by the drastic increase in IR, indicating either lithium plating is happening or immense anode degradation is at play.
small update Tabless design cylindrical cells tests
added low power cycle life graph at 90% (4.15-3.00V) for HP cells.
- 40PL doesn't seem to have a life cycle problem at low power.
- 40P so far shows standard cycle lifetime at 5C discharge
I'm thinking there's no reason why a 40PL should have significantly worse cycle life than a 40P. I assume the active material and electrolyte is identical. Plus @CamLight has a good result in his tests. I was wondering if I could have damaged the internal tabless interconnects on the anode using Micro-TIG welding (1C test is running in BF-2A holder only) Although very unlikely, I'll still try to run the 5C test also in the BF-2A holder. Temperature-wise, it should still come out fine to about 60°C (with Cu strips the 5C discharge end temperature is around 50°C for 40PL and 60°C for 40P)
Also BAK 45D arrived, so on monday I will start with testing. BTCAP 40P (together with Lishen 58SK) are ordered but delivery time will be long like 40 days.
And finally the JP40 with two other interesting samples (not yet released) from 18650-21700 store are also on the way to me.
Huh, I didn't consider spot welding quality to be a factor in testing.
Maybe I just thought too far ahead with my electrolyte hypothesis since I've looked at far too many battery papers these days :p
Now that I think about it, I'm like a drowning man grasping at straws. In fact, I have not yet experienced a single problem with micro-tig welded busbars. So much more straightforward explanation can be that the significantly lower internal impedance caused by the tabless design allow to discharge the cell to a lower DoD level than with a conventional tab design.
From the discharge energy perspective, the value of 2.5 V cut-off voltage at 5C dicharge-rate for the 40P with tab design gives the same amount of energy as the value of 2.9 V for the tabless 40PL. I will try this test setup with 2.9 V cut-off voltage for 40PL first.
Are there no 5000+mAh tabless cells ? It could be a good compromise to get a low ir so it can take high discharge peaks, but still get a a little extra capacity. For my use in an enduro bike I have short peaks of 40-50A/cell, but the average consumption is more like 4-5A/cell.
I noticed this for the first time on 18650-21700's website, they recommend not welding the JP40s directly on the spiral... however, EVE apparently does not consider this an issue.
I'm not set up for cycle testing ATM but (eventually/hopefully) can run cycling on 40PL/JP40 in the near future.
There aren't any in mass production yet. Molicel's P50B isn't tabless but it will probably handle your use case, and will be probably the first one out in MP. Lishen, Tenpower, BAK, and EVE all have tabless 5Ah in the works but my guess is B-samples by EOY if we're lucky -- I've only seen early data so far.
So first results of another tabless competitor BAK 45D were added at the end of the first post :) Tabless design cylindrical cells tests Table results with temperatures will be updated later this week.
Also, I have already opened the BAK cell and confirmed that it is indeed tabless design. I hope to add here photos of its internal structure soon...
More 18650 tabless options should be on the market early next year, high demand from power tools market :)
They should have been available even sooner, makita had some packs with tabless 2.5ah 18650s already shown in catalogues but then removed them some time after, best guess is that they were delayed for some reason.
Very interesting! I believe Makita almost exclusively uses Japanese (Sanyo, Murata) cells... lots of 'custom' cells that they don't post much about unfortunately (VX40, FormulaE as a couple examples).
