Olek.x
New-ish here
I think we can probably do a test and see if it's worthwhile doing.Not really, it depends how big the gap is in reallity.
Thermal grease or paste works normally for a very small gap. (second picture left side)
If the gap is bigger, you can use thermal pads that exist in different thicknesses.
The best is to choose for as high as possible conductivity like 5 to 8 W/(m·K), to fill the airgaps between motor and housing.
On the picture the improvement above tsdz2 is already a lot more, but as you said it isn't the DM-02, only simular.
With Tsdz2 it is about 6mm around the stator, a bit more than 2 mm on the top and 1mm at the axle side of the bare motor.
The improvement will be significant as it is, i feel that the design is close to being optimised now and that for more power its best to consider a higher power motor like the DM-01 we have produced.
Im going to do a post with other improvements to the DM-02 but im looking forward to users getting their hands on them and seeing they are definitely not what they expected.
I saw the comments assuming that they were probably a lower quality copy. Nothing could be further from the truth. Its an improved design and i think people are going to be happy with them.
