Okay, got everything wired..
Cycle satiator prematurely stops charging the em3ev battery every 30 minutes on average, it says it shorted, and i have to force start it again. This happened from 20% SOC as the em3ev battery was shipped all the way up to the 80% i charged it.
I have brand new satiator battery charging cables so this can't be the problem.
The satiator is 10 years old but has very little use.
Phaserunner V2 autotune worked, throttle and brake line show expected voltages, both work, regen works, regen stops accelerator.
System check complete.
Acceleration to top speed on 80A phase / 30A batt is good. About 15 seconds to get to a top speed of 33mph w/o heavy pedaling. Would prefer a little more power.
Motor is incredibly quiet and throttle is amazingly smooth compared to my old infineon clones.
But out in the field, weird and dangerous things happen:
Throttle will suddenly stop working after a few uses, CA V2 displays 11000W, throttle then stops working. Turn off battery, turn it on, then everything is working again... rinse repeat.
I tried pedaling once after this event, the throttle started working again after a while, then the bike went WOT. The ebrake didn't stop the power. I had to grip the front brake super hard and jump off the bike then lift the rear wheel to prevent burning up the motor.
Got back home, checked the voltages of the throttle and brake, everything looks right and responds right, settings seem correct.
Throttle voltage: 0.82v resting, 3.83v fully engaged
Brake voltage: 3.43v resting, 0v engaged.
Using the following settings which seem rational.
Controller & throttle background? had 0 miles on it, never powered up, sat in a shed outdoors for 5 years, in a closet for another 5. No rain intrusion. 0-100F temperature swings and 20-100% humidity swings while in the shed. But the components should be sealed and designed to not suffer the elements.
Ok, the components are 10 years old, close to 1st gen grin components. But this is all very frustrating. I also cannot get a new phaserunner from grin.
Very frustrating.
Sent an email to grin to see if they can help. if i run this controller again, it will be oriented so i can easily yank the power cord.
