Axle Thoughts and drivetrain design observations:
Experience: Apprenticed at a gearbox manufacture which supplied F1, Rallycross, offshore powerboats, Defence etc.
Placements of up to 3 months in milling, turning, gear-cutting, heat treat, quality control, sub-contract buying depts. Also spent a spell at another contract manufacturer to Tier 1 motorsport and watched over the chief engineeers shoulder while he did FEA and asked a load of stupid questions!
The TSDZ2 is a clever design, I'd posit that Bafang haven't attempted a bolt through torque sensor because it's hard to pull off reliably for a low cost.
If this Motor was made in Germany or Japan it would not be breaking. As someone mentioned on this forum it was originally designed in Germany and what we are buying is, in one sense or another a Chinese native knock off. Legit or not, no German owned company would tolerate these tolerances or material quality. The specs were probably marginal for heavy riders pounding across rough terrain BEFORE high quality steel was substituted for Chiniesium, vacuum quenched case hardening was supsituted for a blowtorch and a bucket of water and the tolerances were multiplied by 10.
I sympathise with everyones failures but in order to avoid unnecesary frustration we have to be honest with ourselves about what we are dicking around with here. It is NOWHERE NEAR on par with even the shimano mentioned earlier for toughness. Also the shimano problem looks unrelated to my casual glance.
A bottom bracket is not big enough to allow a sufficiently chunky axle, torque sensor housing AND a structural casting to pass through.
If the materials were (relatively) expensive, the machines that produced the items high quality, well maintained and expertly operated and the quality control sufficiently strict we would have something whose performance (and probably cost) might rival a Bosch or Brosh. But we 'aint got that. We have something that cost a couple of hundred bucks that we are asking to do the same as something that cost a couple of thousand. We are trying to make a silk purse out of a sows ear, and thanks to some solid work on this forum, mainly by casainho, we are succeeding.
I can tell by some of the comments that many people realise this already and others may need a little help leveling their expectations to match where others are at. Hopefully that covers it without upsetting anyone, if it did, I am very sorry. Barring some inevitable frustration everyone seems to be having a great time coming together around this little unit!
If this was not a conversion motor restricted by bottom bracket inner diameter their would be enough space to thicken everything up to cope with the kind of corner cutting any penny pinching necessary to deliver such a capable product at such an amazing price.
When applied to it's biggest potential market the price/quality ratio makes a lot more sense, and of course it's biggest market is millions of commuters who own fairly inexpensive bikes used primarily on roads who are just desperate to pedal a bit less hard.
I personally would not suggest reducing any diameters nor drilling and pinning anything. I read the theories. NO.
2 Observations about the the expense and hassle of replicating the spline.
1. It is not necessary to have a spline.
Consider making a spline-less axle to save on cost and instead welding it to the torque sensor housing to match the existing configuration.
It is necessary for the axle to be a snug but not tight fit in drive side of the torque sensor.
Snug - Because if it is loose it will wobble
Not tight - Because if it has to be pressed in it will not be able to twist the couple of degrees each way every time the crank rotates in order to register torque from the Right hand/Drive Side Crank. This is the whole purpose of the elaborate design and why we are suffering so many breakages. if you only want torque sensing on the left crank weld that sucker up :lol: :lol: :lol:
This type of fit, snug-not-tight is generally refereed to as a 'clearance' fit in machine shops and the tolerances are best investigated elsewhere, sorry, my time is limited atm,
It would be HIGHLY advisable to have dissimilar materials for the contact surfaces between the axle and torque sensor housing because two pieces of hardened steel, which will have a similar hardness to each other can 'Gall' together (sort of like binding, or involuntary friction welding) but honestly, it ain't happening. even taking 1/2mm of each part and using a 1mm bush will weaken it too much given the failures people are posting of BOTH parts, and also, 2 items machined is 2 sets of machining costs.
My melted Nylon fix for a loose fit match up in this area is detailed about 3 pages back and is currently hanging on in after a couple or hours but I haven't had much opportunity to ride the bike lately. It fixes the play cheaply, it's permanence is very much unknown but It is such a thin sliver of material I really hope that it cannot 'flow' out the end as suggested. Who knows though.
This is another potential reason why they have made this a loose fit, if this area does gall up, the motor looses drive side torque sensing.
2. Make a piece that can be welded onto a broken axle.
Obviously use good steel heat treat as necessary and probably do not replicate the circlip groove. Use a star washer type retainer, use loctite, just don't cut a groove there, but re-use most of the existing axle, with spline.
Things to consider -
A. Cut axle down as much as necessary/possible to move the weld location away from the area of highest stress.
Area of highest stress will be on the outer edge of the most outboard journal that is effectively supporting the axle, I do not hold out much hope that this is the double (with modification) ball bearings under the lip seal unless they are a good fit on the shaft or have the shims in, however maybe the axle deflects (bends) enough that is contacting the bearing inner journal?
B. Make the replacement piece to be welded to the axle a larger diameter and find a thinner/wider bearing to carry it.
Right, that took way too long to write, I have to go. Good luck to anyone experimenting with this, If I get a chance to do more I will share my progress.
