casainho
10 GW
- Joined
- Feb 14, 2011
- Messages
- 6,058
I think VESC can switch to sensorless after the motor get over some speed, so, hall sensors are only used for the startup, so get the best of booth worlds.beemac said:Just did a test with the sensors connected - works either way just fine - hard to say if the motor sounds better, it's so quiet I can't hear it over the bench PSU anyway!
For the startup, you will probably only see if sensorless works well or not when there is load on the motor, so on your EBike and with your weight added.
