casainho
Legend
- Joined
- Feb 14, 2011
- Messages
- 6,117
Great work!!anszom said:As a bonus, it should be easy to port this to casainho's DIY display, as the electronics are quite similar.
I just got OLED SPI version work, that is the same as SW102, so closer / easier to port your firmware.
I am in the process to release a stable version of the OpenSource display firmware, so, I will not port or test your firmware right now.
Also I am starting on another different project, the Xiaomi M365 scooter motor controller and display firmware and so I need a stable version of the display.
I need a firmware that is easy to adapt for different project / device and the previous SW102 firmware was developed thinking on that, with the layout and fields, is quick to adapt a different design. You firmware seems, at least visually, very specific to TSDZ2 and I wounder if it follows the same ideas as previous firmware on the layout and fields.
