The Technical Reference forum is meant just for that, if you make a thread ask an admin to copy it over there then its just read-only.
Wow, great post! I'm 64 and building my first ebike. It's on a new Specialized Roll Elite which is a beefy comfort style bike. Like you, I ride for exercise and enjoyment, but need a little help on the ever growing hills and strong winds. I have a 48v 500w TSDZ2 coming next week. Hope it's not an overkill for me.hobbyvac said:Its tough to make a product that pleases everyone. It will be interesting to see how the e-bikes will evolve into categories and blend with the cycling community. I can appreciate the need for speed and power but I have motorcycles for that. My attraction to the TSDZ2 system is from an ex mtn bike racers perspective. The 250 watt 36 volt system is the perfect assist for a 61 yr old. I still have good leg function and the desire for a good workout but the extra help just makes me feel like a 20 yr old and lets me match the pace and distance of my younger buddies. I spend all of my time at level 2 assist because 3 doesn't let me "push" on the pedals enough. It feels too much like I'm pedaling air which actually hurts my knees more. Level 4 is not usable for me except on the road in high gear. For my use the sweet spot is 36 volts. You have no durability issues, can use cheaper, lighter batteries and I have more range than my legs.
I suspect (and hope) that the industry splits into two categories. There will always be a large group who want high wattage throttle equipped bikes but I hope they keep a low power torque sensing category and I hope that option becomes accepted for use on mountain bike trails. I fear that we will become our worst enemies and never be welcome on trails or sidewalks. We could get stuck in the middle,... not quite road legal but not sidewalk or trail legal either. It will be a challenge for the industry to avoid an image of speed crazed hooligans that need to be banned from having too much fun.
I still ride mountain bike trails until the rules catch up but I shut off the motor and make eye contact and conversation when passing cyclists or hikers so they don't look down at my bike. So far I have managed to remain invisible but I fear my over sized grin will give me away
Tell me about the LB01 motor please.AWD said:15amps seems to about the limit the system will be dependable at. At least in our experience.
In order for the TS to run 52v it needs the 52v controller.
There are bugs in the TSDZ2 that need to be worked out. We have had controller issues with the 52v in regards to the torque sensing that have been particularly annoying. The stock 48v seems to be trouble free. Also the nylon gear doesn't like the extra power and thus the brass (much heavier) replacement.
We have received info that the soon to arrive LB01 will have a different nylon gear that has more "tooth" to it. No word on the controller or overall look at the new system yet.
casainho said:Go and take photos of XH-18.
Use an FTDI cable to read what data LCD send to the controller. You will need to change parameters on LCD and figure out which bits does change.
Than do the same for the controller, you can wire the FTDI in parallel to original lines, that works and is what I did.
I need to know the protocol/data sent and received by the LCDs, to implement on the firmware.
Why not use the Bafang shift sensor??John and Cecil said:Very nice build GGG!
Has anyone made an electronic "clutch" yet for this motor? The "stop pedaling" or "releasing throttle" works but I think the timing could be much better/faster, especially when on inclines. It can probably be wired to the display instead of the brake lever.
Currently you can buy a bottom bracket torque sensor for 40€ and it works very well. Very fast response also, and it can be used as "human power" (torque * cadence), torque sensor or PAS modes.gggplaya said:My last e-bike was a geared hub motor with only cadence sensing. I didn't like it at all, and the motor continued to spin for 1-2 seconds after you stop pedaling. This system stops very quickly and responds fairly quick, with about a quarter turn of the pedal. 500W is plenty, I just wanted lots of torque to get up hills, which is does very well in level 4, however, I still want a workout so i'll keep it on level 1 or 2 most of the time.
casainho said:Why not use the Bafang shift sensor??
Sorry, I wanted to mean in future with our firmware. We will need to test Bafang shift sensor and see if it really works well... I still don't know how it detects gear changing....John and Cecil said:casainho said:Why not use the Bafang shift sensor??
I did not know they would work with the Tdsz2. Is anyone here using a shift sensor and if so how did you wire it?
I think there are on the market sensor for hidraulic brakes -- please note that "the sensor" just needs to short 2 wires when braking meaning that can be something simple as a mechanical switch.John and Cecil said:No I am not using the brake levers, I have hydraulic brakes and the sensors do not work for them.
Waynemarlow said:Its a pity the DiVinci won't change under load, but surely that must be the case even just peddling ?
TSDZ2 also has a candence sensor + torque sensor. Torque sensor is much faster to react and so it is used to detect stop pedals.Waynemarlow said:"The problem with cadence sensor bikes is that they keep spinning for 1-2 seconds after yous top pedaling. So they're not like a normal bike. They actually introduce a problem shifting, so a gear sensor is crucial".
But the TDSZ2 is not a cadence sensing motor setup unlike the Bafung.
Never said it wasWaynemarlow said:"The problem with cadence sensor bikes is that they keep spinning for 1-2 seconds after yous top pedaling. So they're not like a normal bike. They actually introduce a problem shifting, so a gear sensor is crucial".
